Old 12-14-2007, 05:45 AM   #1
ibad57
ibad57's Avatar
Tilt front ends-bed
Has anyone seen or done fab work on tilt front end on the 72 C10
Im doing research this winter as production during the cold season
Cost too much to heat garage. My avatar is what im looking to do with my project and planning will save lots of money and trouble. If you have any picks or links to a truck that has had this done add below
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 12-14-2007, 05:55 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Tilt front ends-bed
Yes,here are some vague pics pm me if you have any Q,s
http://67-72chevytrucks.com/vboard/s...=1#post1576523
sneakysnake is offline   Reply With Quote
Old 12-14-2007, 08:34 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Sweet project sneakysnake
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-14-2007, 09:13 AM   #4
crazy longhorn
Fabricate till you "puke"
Here are a couple shots.... http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-15-2007, 04:26 AM   #5
ibad57
ibad57's Avatar
Thanks for the pic do you have any pics of the front tilt henge I was considering henging compleate radiator core support and remounting rad-condensor to frame just woundering how to mount bumper and if I can keep bumper funtional it looks like some real design stratigy is needed but I got all winter to plan it out need more pics showing henge location and bumper
Old 12-15-2007, 05:04 AM   #6
sneakysnake
Ive seen it done different ways but for strength, I made a hinge from 4" C channel back to back ][ with 1" diameter segmented pipe welded at bottom for a hinge. I then took a sawall and cut the frame and bent the top open and put in the hinge. After squareing and welding in place I the sawed the frame into allowing it to fold over.The frame ends stay entact so the bumpers just move with rest of it.
Old 12-15-2007, 05:54 AM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would think that unless you use the weight forward of the hinge as a counterweight you would want it as light as possible.sneakysnake's version seems to use the bumper and frame parts as part of a counterweight.If you did not do it this way i think it would be awfully heavy to open.JMHO.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
