Old 12-14-2007, 09:22 AM   #1
87Bob
Thumbs up 1985 "H" engine code owners look here!
I just had my QJet rebuilt. In the process of removing it I discovered that the Electronic connector on the right front corner was burned and no longer any good. The part it goes on is called a solenoid-dual capacity pump in the GM parts breakdown. I spent the better part of three weeks trying to find a correct replacement part. The part is no longer available from GM. But I have found a source for the repair part plus many others that are hard to find. The company is Pacific Industrial Components Inc. Eugene OR 97402 800-547-5328. The part number is a 5615C
http://www.picowiring.com/pdf/PICO-27-28-29.pdf
I spoke with the company and they deal through small jobbers across the U.S.. If you cannot find someone locally that handles their products call them they'll hook you up.
87Bob is offline   Reply With Quote
