Old 12-14-2007, 01:11 PM   #1
496stroker1
need to see some electric fan installs
would like to see some e-fan install on big block trucks to see what ive got in store. i know there will be clearance issues with lwp, bought a mark VIII today so if theres anyone out there with this kinda fan please post pics!
496stroker1 is offline   Reply With Quote
Old 12-14-2007, 04:08 PM   #2
71Rat
ran out of money
71Rat's Avatar
Re: need to see some electric fan installs
im also interested.... ttt
thanks guys
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 12-14-2007, 04:22 PM   #3
c10addict
c10addict's Avatar
I need to see them too...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 12-14-2007, 04:27 PM   #4
Hoss72
Wow Daja Vue I just posted this in the Blazer side, My new ride has a Flex_Lite fan and no shroud Scares the crap out of me. Thinking of running Electric myself.
Hoss72 is offline   Reply With Quote
Old 12-14-2007, 04:38 PM   #5
TotalChevy1
TotalChevy1's Avatar
I don't have any pics but I installed one on my truck, but it is only a small block. I tried to use it with the factor schroud but couldn't do it and didn't like the way it looked by itself. I did trim mine about 3/4" so it was less than 5 inches talk at the motor
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 12-14-2007, 06:13 PM   #6
496stroker1
ttt gotta be some guys on this forum running mark VIII fan with a big block
Old 12-14-2007, 06:28 PM   #7
ofnaman
ofnaman's Avatar
I have a bbc in my truck with a short water pump with a 14" electric fan. I left the fan shroud in for hwy driving, but I am going to take it off. The truck never gets hot, as it has the huge 4 core radiator in it. There is about a 1/4" gap between the water pump shaft and the fan motor. I could have offset the fan, but I like it centered. Sorry, no good pics yet.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 12-14-2007, 09:17 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a couple.
http://67-72chevytrucks.com/vboard/s...=electric+fans
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-15-2007, 01:45 AM   #9
70GMCer
70GMCer's Avatar
Saw this write up and this is the way I'm going. http://67-72chevytrucks.com/vboard/s...=electric+fans
Already got the fan and relay kit ready for the install.....
I tested this inside the shroud and it moves some serious air.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-15-2007, 09:05 AM   #10
496stroker1
ttt
Old 12-15-2007, 09:46 AM   #11
496stroker1
seen all the ones on the board. i was kinda lookin for mark VIII or taurus setups. im doing a 496 so i need some serious airflow
Old 12-15-2007, 09:55 AM   #12
71Dragtruck
71Dragtruck's Avatar
Here's mine from Classic Heartbeat.
http://67-72chevytrucks.com/vboard/s...d.php?t=201152
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-15-2007, 10:26 AM   #13
TotalChevy1
Do a search on Mark 8, When I was looking I remember there was a memeber that had installed it and he was running a 396 with no problems. I think he had to trim it but that is not a bid deal. I just sold mine last week, it was ready to mount.
Old 12-15-2007, 11:37 AM   #14
SCOTI
SCOTI's Avatar
I have one installed on a 68 core support w/a 4-row factory radiator that I can get a pic of later tonight after work.
It's not installed on a running/completed truck though. Currently it's just a mock-up (fan/shroud, radiator, core-support bolted together)..... Would that work for you?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-15-2007, 11:43 AM   #15
496stroker1
sure SCOTI, are you running a big block? if you are how much clearance do you think you will have?
Old 12-15-2007, 02:43 PM   #16
SCOTI
SCOTI's Avatar
Not on this one. But, this one is a test for my other 'RestoRod' that will have a 'big' big-block. This one is sbc that has been moved slightly from the factory position (Dropmember).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-15-2007, 02:54 PM   #17
70GMCer
70GMCer's Avatar
I was told that those Taurus ones pull a lot of amps. Something like 45 amps. Just a thought in case you don't have the right alt or relays.....
1997 GMC Sierra Ext
1965 Mustang
Old 12-15-2007, 02:57 PM   #18
496stroker1
yep i know. going with 100 amp minimum maybe 140. place in calgary has chrome powermasters for 100 bucks for the 100 amp and 140 bucks for the 140 amp.
Old 12-15-2007, 03:02 PM   #19
496stroker1
scoti you said you moved the engine back a little bit? wonder if theres enough room to move a big block an inch or two back. il probly have the cab off so it should be a big deal just wonder about firewall clearance
Old 12-15-2007, 05:00 PM   #20
496stroker1
should also ask what is the clearance with a big block with long water pump from pump to rad?
Old 12-15-2007, 05:48 PM   #21
clay68c10
clay68c10's Avatar
I have the mk8 fan and a 454 with a 4 core radiator. I had to trim the shroud and mounted it off center so the wp pulley would clear. I'm running a 105A alt and a PWM fan controller. I don't have any pics, maybe I'll come up with some this weekend.
With the BBC in the stock frame location, you'll have about 1/2" between the long wp pulley and your radiator. It was too close for my liking, so I stuck with the short wp setup.
This setup kept me cool all this summer without a/c. I got that working right about when it started cooling off (typical for me). With outside temps in the upper 80's it ran warm with the a/c on but never got too hot.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is online now   Reply With Quote
Old 12-15-2007, 07:02 PM   #22
496stroker1
im still mulling the idea of a short pump, then i gotta find ALL the brackets for it and pulleys so i wanna stick with the long. definetly have to offset the mounting of the fan cuz it will hit the motor probly for sure. it will be close but i have i pic and if it hit around the area where i outlined i could probly just take out one of the fan supports and have the pulley go inside the shroud a bit as long as it didnt hit the fan. i dunno im just throwin some ideas around
Old 12-15-2007, 07:15 PM   #23
SCOTI
SCOTI's Avatar
You definitely won't be able to move a BBC back in these trucks. At the factory location, it's already pretty close to the firewall.
My sbc combo (in my Beater 68) will actually be moved forward (toward the grille) & up (crank C/L higher than stock) to clear the aftermarket crossmember & corresponding R&P that I'll be installing. I'm using a similar crossmember in my RetroRod 67 w/the BBC, so it will pretty much do the same thing.
As for pics . . .... I grabbed the camera but the memory card was full. I started scrolling through pics to delete some & actually found some pics I had taken of the set-up. But, when I tried to down-load them, the camera wouldn't do squat & I'm not sure WTF is going on. I'll try again this weekend if Clay doesnt beat me to it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-15-2007, 07:31 PM   #24
SCOTI
SCOTI's Avatar
Ok..... I did some digging & found some pics of the 'mock-up' that I already had in an old thread here on the site. The ones in my camera are different because I had the tape measure showing various depths & dimensions.
Here's what I can offer for now . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2007, 05:44 AM   #25
TotalChevy1
You don't have to center the fan, if you mount it to the driver side edge you should have plenty of clearance.
