Quick frame question
Are there any differences in the frames on 67-72 chevy c10's? I have a '72 and I am looking at a short frame from a '68. I know the obvious stuff like the 6 hole/5 hole stuff but I am wanting to know if the frame rails themselves are different? The control arms? Cross members? etc.. Any help is greatly appreciated.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
Re: Quick frame question
Power steering box indent will not be on the '68, unless it had power steering, and trans crossmember from standard to auto are different. Other than that someone wiser will have to chime in. And the ball joints are different on the '72.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) Last edited by bobthecop; 12-15-2007 at 04:25 AM. |
It's a catastrophic success.
![]() Join Date: Jan 2003
Here is a a pic of what "bobthecop" is refering to.
Active Member
The frame rails are wider at the motor mounts on my 68 and need to trim for BB mounts.
Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
Project: years too late.
i have a 68 SWB frame and im using it for my 71...good to know all this. Mine has origional power steering yey! and yes im replacing the 6 bolt hubs with the 5's off the 71
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Two of the bolt holes for the front crossmember will be slightly off if you try to bolt the 72 crossmember to the 68 frame. Just slightly enlongate them.
Some of the rear brake hose tabs are slightly different too. Steering box dimple like shown above.
