I'M TRUCK CRAZY!
Gasket???
Hay, good morning! Does anyone know the part # for a Felpro gasket. I am looking for the blue one piece, dry seal, oil pan gasket. It comes with bolts. The one I want is for an 85 350. There are 3 for the small block that I know of. The difference is the dipstick hole.
Gasket 1 has dipstick on passenger side. Part # O?????T Gasket 2 has dipstick on driver side. Part # O34509T (I think that is what I saw last night, we were closing up) Gasket 3 has dipstick holes on both sides. (universal) Part # O34510T (if i remember corectly) this i have I need the part # for gasket 1. I know someone out there knows this. I have seen all three in my hand. I work for a parts store. (Part Time 2nd Job)Can't remember ![]() ![]() Last edited by LOW DOUGH; 12-15-2007 at 04:45 AM. |
#2 | |
Re: Gasket???
I think what you are looking for is the Permatorque. #OS34510T
Its one peice...and even comes with fastners to boot. ![]() Photo is illegally bootlegged from Summitracing.com
I'M TRUCK CRAZY!
Re: Gasket???
that is the one i have. I am looking fot the one with the dipstick on one side. The passenger side that is. I have found the one on the driver but that is for an older V8. We're going in the right direction. I know some one knows this
![]() Join Date: Aug 2005
Re: Gasket???
Only one I found....
OS34500R- Fits 86-99 SBC |
#5 | |
Re: Gasket???
Why not just use a stocker then?
This is the stock, one peice for 87-99 SBCs. ![]() Photo used again without permission from Summitracing.com
I'M TRUCK CRAZY!
Re: Gasket???
i have an 85 block. 87 -99 wont work... the rear main is different
Firefighter
Re: Gasket???
Os34500r, But For 1pc Rr Main
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#8 | |
Re: Gasket???
How the hell do you have the dipstick on the right side then? They didnt start doing that **** till 87 with the new style block.
Firefighter
Re: Gasket???
Victor # Os30568rrh Is The One. Fel- Pro Only Os34509t 1957-1974, Os34510t 1975-1985
I'M TRUCK CRAZY!
Re: Gasket???
73 74 75 or something like that the dipstick changed sides. That's how you can tell if a motor is realy an old one from these trucks or an old car. I forget what year it was changed. Before 75 or so it's on the pass side after 75 or so it's on the driver side
I'M TRUCK CRAZY!
Re: Gasket???
Dave's not here, man
Re: Gasket???
The one I just bought from NAPA for my truck was an OS34500R, and my dipstick is on the right side of the motor ('86 305). Make sure the one that you get is blue. Autozone sold me a gasket that they claimed was Felpro, but it was orange. It even had the same part number as the Felpro, but it was a piece of crap knock-off that leaked like crazy; sucks doing it twice.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 12-15-2007 at 11:10 AM. |
#13 |
Re: Gasket???
Maybe another consideration is the timing chain cover, I had to get a thick lip for my alum. cover on my one pc. But maybe you are running a stock one
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#14 | |
I'M TRUCK CRAZY!
Re: Gasket???
I also put this up in the 73+ side and was given the same gasket. OS34500R I will look at this tonight at work. |
#15 |
Right turn Clyde
Re: Gasket???
I believe its 80 and newer is passenger side dipstick 79 and older driver side. 80-85 is two piece rear main. 86 and up are one piece rear main seal. Then there is also the thin and thick front seal but I'm not sure about that. You will need to have the oil pan and timing chain cover matched up. You can measure the distance of the lip on the oil in the center. Someone else might be able to help better on that part.
Did you silicone where the timing cover and block meet. Or the rear the rear main cap and block? Just like the four corners on the block before you install the intake gaskets.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#16 |
Re: Gasket???
Might be the pan. I bought a brand new steel pan from Summit last year and try as we might, we couldn't get that thing to stop leaking. Tried an old pan that was laying around my friend's shop out of desperation and no more problems.
#17 | |
I'M TRUCK CRAZY!
Re: Gasket???
I do have a junck yard timming cover. I am wanting to get a brand new timming cover to. Then it will all be fresh and new. |
#18 |
I'M TRUCK CRAZY!
Re: Gasket???
Yeah that is what i am thinking. I have taken this motor out 5 or 6 times and used the same pan every time. This pan that is on it right now was floating around the bed of my truck for a year or so along with all the other junk i had back there. It was my DD so it is probably bent a little were you can't tell. It leaks out of the front. But the balancer doesn't have oil on it so it has to be the pan. I have done everything else to fix it with no luck. I would say it has been leaking for 5 or 6 years OMG! One quart every other day when it was the DD
#19 |
Re: Gasket???
Could also be the rear main seal. When they leak it can look like it's coming from the pan.
#20 |
I'M TRUCK CRAZY!
Re: Gasket???
IT is definitely coming from the front. It gets blown all down the pass. side of motor. Have no wheel wells in so it gets all over the right front disc. After driving hard it smokes and people tell me my truck is on fire. Nope it's not.... But close
#21 |
![]() Join Date: Nov 2007
Re: Gasket???
There are 2 different size gaskets for different oil pans, one has a thicker front seal and another uses a thin front seal. The difference is in the distance from the rail of the oil pan and the lowest part of the curve from the front seal.
If you bought a different oil pan, it may be the old style which requires a thin seal. Best way is to measure. Here is a link, it is hard to read but maybe you can zoom in. http://books.google.com/books?id=GUC...CaEj5ttV-drmsU
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. Last edited by webfoot; 12-16-2007 at 12:53 PM. |
#22 |
I'M TRUCK CRAZY!
Re: Gasket???
thanks Webfoot. I know about the 2 sizes. I am prity sure i have the right thing. But of course i am going to check.
anyone ever used this? ![]() |
#23 |
Professional Beer Tester
Re: Gasket???
LOW DOUGH, you might check to be sure you are not missing the short 3/8" bolt that goes in one of the holes on the front passenger side of the block. One of these holes(I think the top one) is drilled into the crankcase directly in line with the fuel pump push rod. Some people pull that bolt out and stick a longer one in there to hold the push rod up while changing the fuel pump. I've run across a couple leaking there before. It would only leak when you drove it, not just sitting there. Just a thought.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
#24 | |
I'M TRUCK CRAZY!
Re: Gasket???
