Junior Member
73+ SPINDLES, What all needed to convert???
If I want to run 73-88 spindles on my truck what would I need to convert it over? Could I just do spindles or do I have to swap the hole crossmember? I have a set of drop spindles and disk brakes off a 75 that I want to use is why I ask.
Thanks! |
"Trucks with Class"
![]() Join Date: Jul 2000
Re: 73+ SPINDLES, What all needed to convert???
Upper balljoints & outer tie rod ends from a 73+
...and adaptor sleeves for the tie rods on a 70 & earlier |
Exactly!
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
Junior Member
Fabricate till you "puke"
Also lower ball joints on the 70 & older....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Junior Member
This will be going in my 68, so to make sure I have it right I will need:
73+ upper ball joints 73+ lower ball joints 73+ tie rod ends and custom tie rod adjustment sleeves. Is this correct???? |
That looks right. If you are replacing all the tierod ends, you could also opt for the center link(boneyard pc only) from the 73 donor truck & just use all the tierod pcs for the 73, or maybe better put....just swipe all the steering linkage from the 73, including the pitman & idler. It should all bolt on. crazyL
But.....you could always just swap the whole cross member right?????? Seems like it would be easier?
A............
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
I did this. You need this sleeve available at cpp:
![]() http://www.classicperform.com/Store/...uck/CP4SCS.htm and you need to use 67-70 outer tie rod for use on the inner. Last edited by jlaird; 12-15-2007 at 06:20 PM. |
Texas Big Wig
Not to hijack, but...
I have a 67 GMC that Ima change over to 73+ disc brakes & I have a 70 somthin parts truck that I wanna nab the parts from So lemme see if I got this strait I need to get some new upper & lower BJ's that are 73+ Pull the steering off the parts truck & put it on my 67 & thats basically it ??? |
