Old 12-15-2007, 11:54 AM   #1
Frizzle Fry
Frizzle Fry's Avatar
Rear Shock Recomendation
I'm moving my rear shock upper mounts in and will be replacing the shocks to increase travel. I need a minimum extended length of 19.75" and a max compressed length of 13.5" but would prefer more like 20" ext and 13" comp. Any suggestions? I have an email in to KYB but I figured you guys might have some good recommendations.
Frizzle Fry is offline   Reply With Quote
Old 12-15-2007, 12:58 PM   #2
grnddwn
belly dragger
grnddwn's Avatar
Re: Rear Shock Recomendation
If you go on monroes website you can look through their shock dimension guide and it will tell you if a shock like that exists, and then you can reverse look up the app from the part # andfind out what it's for and order shocks from whatever manufacturer you wish for that vehicle.
SAVE THE PLANET DRIVE AN OLD TRUCK
grnddwn is offline   Reply With Quote
Old 12-15-2007, 01:50 PM   #3
cdowns
cdowns's Avatar
speedway motors lists shock dimensions in the catalogue
Old 12-15-2007, 02:21 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
Monroe link....
http://monroe.com/catalog_lookup/ocl_miscappinfo.asp
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-15-2007, 08:00 PM   #5
SCOTI
SCOTI's Avatar
That sounds close to the dimensions of the rear shocks I swapped to on my 68 Beater. I used some Bilsteins for a 88~98 Chevy w/a 4/6 drop (that was their catalog ID). The install required a custom (homemade) upper bracket & 3" more travel vs. a stock 67~72 GM rear truck shock.
Tomorrow I'll try & find the dimensions I documented out in the garage to confirm the exact measurements.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-15-2007, 09:38 PM   #6
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I used the mounting chart then the dimension chart to find the shocks I needed. The ones I got for my truck are the Monroe Sensatrac PN 5850. It has an L2 top mount and LS47 lower which matches the factory mounts, a compressed length of 12" and extended length of 19". It was the closest thing I could find and is actually listed for a Corvette in the application guide. Hope this helps.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 12-16-2007, 05:19 AM   #7
SCOTI
SCOTI's Avatar
I started my search using the same logic.
What concerned me was that I find it hard to believe all shocks are valved the same (from the same product line/manufacturer). Does any shock that fits have the right valving for my swb truck application? I decided that I would look for truck applications that were real close to my needs.... a 88~98 4/6 dropped Chevy seemed real close. I did have to refigure my shock bracket travel on the truck but it was worth it to me to have the same type shock F/R.
Just a thought.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2007, 07:43 AM   #8
XXL
Seņor Member
XXL's Avatar
Monroe# Top Bottom Comp Ext
32228 L1 LS26 12.875 21.375
32231 L1 LS26 13.375 22.875
I just installed a pair of the second model on the Wallet Eater.
XXL is offline   Reply With Quote
Old 12-16-2007, 07:45 AM   #9
XXL
Seņor Member
XXL's Avatar
No, but as you indicate... once you find a part number that "fits" you have to dig into the original application to see if weight, etc., are "appropriate."
The numbers I posted above are both for 1/2 and 3/4 ton truck applications... the one I chose is actually for a Frod pickup
Old 12-16-2007, 08:33 AM   #10
Frizzle Fry
Right on guys! I really appreciate it. And I'm more edjumacated now too :P
Old 12-16-2007, 12:25 PM   #11
entourageguy
Yellow truck club
I'd been looking at the 5850 shocks as well but came up with 9.5" comp and 14" ext.4.4" of travel. L1 and ls14 mounts corvette
Also a 555003 with 9.6" comp and 14.75 ext 5.1" travel RV shock
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 12-16-2007, 01:54 PM   #12
SCOTI
SCOTI's Avatar
Originally Posted by XXL View Post
.....the one I chose is actually for a Frod pickup
Obviously, we both had the same brilliant thought process. But..... I selected a shock for a Chevy truck & you picked one for a 'Frod'.
I'll let the rest of the board decide your fate . . ......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2007, 02:45 PM   #13
XXL
Seņor Member
XXL's Avatar
What's that rack of yours off of?
Old 12-16-2007, 03:55 PM   #14
SCOTI
SCOTI's Avatar
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2007, 07:03 AM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
DM uses MII...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-17-2007, 11:09 AM   #16
SCOTI
SCOTI's Avatar
Oh.... I didn't realize the question was about the Dropmember (since it's not installed yet).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2007, 11:54 AM   #17
XXL
Seņor Member
XXL's Avatar
Phew. That little jab took a lot of posts
Old 12-17-2007, 02:33 PM   #18
SCOTI
SCOTI's Avatar
XXL = 1
Scoti = 0
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2008, 06:57 AM   #19
Frizzle Fry
Just wanted to close the loop on this and say thanks again for the input.
I ended up going with a Monroe Sensa-Trac 37037
No more shock limited travel. I have almost 10" of rear travel now That's more than enough for my purposes.
Pics:
That's a 16" ruler:
Now I need to do something about that exhaust...
Old 01-05-2008, 07:38 AM   #20
XXL
Seņor Member
XXL's Avatar
Pics:
Good choice!
And that KYB looks like it's got another couple hundred thousand miles of life left in it
Old 01-05-2008, 08:02 AM   #21
Frizzle Fry
Good choice!
Those KYBs were f'n hosed from being over extended by the bags. One actually started leaking
Old 01-11-2008, 07:07 PM   #22
67L30WGN
67L30WGN's Avatar
Although your application is a little different from mine, I'm curious, if you can remember back to when your KYB's were still working, how they compare with the Monroes for ride. I've always had KYB's in my cars, but was considering the Sensatracs for my stock truck, thinking they'd provide a slightly more comfortable, if less performance minded, ride.
1972 Cheyenne Super 10 LWB
1965 Nova SS Evening Orchid
1967 Nova Wagon Factory Disc (1 of 565), 327/PG
1964 Ford Fairlane 500 HT
1962 Nash Metropolitan Convertible (Wife's car)
67L30WGN is offline   Reply With Quote
Old 01-11-2008, 07:10 PM   #23
Slmd92DIME
Slmd92DIME's Avatar
That burb is bad
Slmd92DIME is offline   Reply With Quote
Old 01-12-2008, 08:40 AM   #24
Frizzle Fry
I'm not going to be able to make a direct comparison yet because I also removed the rear sway bar when I switched to the monroes. I can let you know after I put the hellwig on there. But FWIW I thought the KYBs felt great in the stock config.
Old 01-16-2008, 08:49 PM   #25
67L30WGN
67L30WGN's Avatar
I installed a set of Sensatracs on my stock truck today. They are firmer than I expected based on the marketing description, but not so firm as to be uncomfortable. I like them and am glad I didn't go with something firmer. They go a long way toward helping "Annie" (Shy Anne) ride more like a car.
