12-15-2007, 04:13 PM | #1 |
drop sindles
will belltech 1/2 ton spindles work on a 3/4 ton?
12-19-2007, 12:40 AM | #2 |
Re: drop sindles
ttt
12-19-2007, 04:43 AM | #3 |
Fabricate till you "puke"
Re: drop sindles
NO, not unless you are planning to swap to 1/2 ton suspension(5 lug). This will also require swapping the lower a arms, all ball joints & steering linkage. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-19-2007, 09:11 AM | #4 |
Re: drop sindles
thats wat i thought, but i have all that minus new balljoints the true question now would be do i want to convert my perfectly good 3/4 to a 1/2.....
12-19-2007, 12:13 PM | #5 | |
Re: drop sindles
12-19-2007, 03:19 PM | #6 |
Re: drop sindles
thats a clean truck how much body drop is that?
nice touch with the 6spd too |
12-20-2007, 04:54 AM | #7 |
Re: drop sindles
1 1/2" on the body drop.....I would have gone more, but with 4" off the top,it starts to get a little crowded in the cab. crazyL
12-20-2007, 02:06 PM | #8 |
Re: drop sindles
i bet it looks soo clean thomakes me want to convert mine to 1/2 ton
