Old 12-15-2007, 06:34 PM   #1
PrerunnerRob
PrerunnerRob's Avatar
Suicide doors
Who has done them, what hinges did you use, and what latches did you use...Thanks!
Rob
PrerunnerRob is offline   Reply With Quote
Old 12-16-2007, 09:06 AM   #2
L0WRIDE
L0WRIDE's Avatar
Re: Suicide doors
hey PrerunnerRob I got the autoloc hinge kit and bear claws.If you want to know how to make the suicide door hinges another board member has a web site showing you how heres the site www.suicided.com just click on suicide and its all there
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 12-16-2007, 12:27 PM   #3
60ratrod
yes, i do
60ratrod's Avatar
Re: Suicide doors
as a fellow smoker i enjoyed the fact that he listed nic as one of his tools. also i enjoyed the fat bastard references he made of himself
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 12-16-2007, 06:07 PM   #4
PrerunnerRob
Re: Suicide doors
How did the autoloc kit work out for you? I was looking at their hinge kit and the bear claw latches and was wondering how well it all works.
Old 12-16-2007, 07:25 PM   #5
L0WRIDE
L0WRIDE's Avatar
Re: Suicide doors
i still haven't set up the bearclaws but the hinges work well the only problem if found was if you weld the top hinge to the door frame you cant get the the pin and if you need to replace the bushes at any stage you wouldn't be able so i bolted the top hinge so its removable hope this helps
62 HARDTOP NOVA
Old 12-16-2007, 09:20 PM   #6
PrerunnerRob
Re: Suicide doors
Can your doors open 90 degrees, or do they contact the body? Also, do you have to have large slots cut into the door to make the hinges work? Sorry to hound you with all these questions, but I'm trying to plan and buget alot of upcoming work on my truck. Thanks,
Rob
Old 12-17-2007, 12:07 AM   #7
L0WRIDE
L0WRIDE's Avatar
Re: Suicide doors
yes the doors open almost 90 degrees i had to cut slots into the doors i ve got one of the doors of at the moment as I'm stripping the paint of so I'll take some pics of the slots and the bracing for ya in the morning and no your not hounding me this is what this site is about
62 HARDTOP NOVA
Old 12-17-2007, 05:17 AM   #8
PrerunnerRob
Re: Suicide doors
Awesome! I'm going to go buy new frame clip material today, I'll check back later on.
Old 12-17-2007, 05:21 PM   #9
insanebehavior
Re: Suicide doors
i just started working on my suicide doors today. thanks as i really enjoyed the article on suicide.com. i first purchased some autoloc suicide hinges and i just didn't do enough homework to feel comforatable working on them. i ended up buying hinges from electric lite. i think they are bad to the bone but it is going to be alot of work. i have tried to find some articles but have not had success. the biggest concern is the door hitting the side of the truck when opening......other than this i am trying to position the hinges. i am not sure if i am close or not.
insanebehavior is offline   Reply With Quote
Old 12-17-2007, 06:49 PM   #10
PrerunnerRob
Re: Suicide doors
After close examination, i think i might be able to get the stock hinges to work. Suicide would be super bad ass, but i am concenrd about the large slots and holes left by suicide hinges.
Old 12-17-2007, 09:19 PM   #11
L0WRIDE
L0WRIDE's Avatar
Re: Suicide doors
here are some pics these doors aren't finished yet the big slots get filled in all you'll see is six holes were the bolts go through to hold the hinges hope this helps
62 HARDTOP NOVA
Old 12-17-2007, 09:25 PM   #12
L0WRIDE
L0WRIDE's Avatar
Re: Suicide doors
here's the bracing
62 HARDTOP NOVA
Old 12-18-2007, 06:24 PM   #13
Rokcrln
Rokcrln's Avatar
Re: Suicide doors
Looks like it should work out just fine for you. I like the cross brace over to the stock hinge bracing, good work! One concern I have is with the lower hinge it looks like you welded the brace to the outer door skin. Do you think that if the door flex's that that will cause damage to the outer skin after paint. Reason I ask is I tacked a brace to the door skin once and just from heat and cold it showed thru down the road.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-18-2007, 06:45 PM   #14
70 Suburban
Rods
Re: Suicide doors
where did you say u got that kit and how much
70 Suburban is offline   Reply With Quote
Old 12-19-2007, 12:32 AM   #15
L0WRIDE
L0WRIDE's Avatar
Re: Suicide doors
the only bracing that is welded to the outer skin is the top hinge and that is welded to the old door handle position
all the bracing it welded to the frame thanx. the kit was from autoloc and it was $400 new Zealand dollars i guess i was it the right place at the right time cause they normally sell for $800-$850 thanx
62 HARDTOP NOVA
Old 12-19-2007, 03:20 AM   #16
PrerunnerRob
Re: Suicide doors
Here are some hinges and latches
http://www.fbirides.com/shopping_dep...at_idno=257921
http://search.ebay.com/search/search...ide&category0=
