Old 12-15-2007, 09:42 PM   #1
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
ignition problems
I've been experiencing this problem on and off since I first got my suburban
in Sept of last yearand BEFORE i started to do any mods on it.
What is happening is every once in a while, when I shut the engine off and immediatly turn the key all the way back to the accessory "ON" position, the engine will continue to run. Voltage gauge, temp gauge, fuel gauge and the oil gauge all shut off but the engine is still running. I can rev it up and let it idle. But it won't die until I shut off the ignition switch to pull the key.
Could this be caused by a faulty ignition switch or should I look further?
This is a T.B.I. engine not carbonated so I know it's not "engine run on" like the old carbonated engines did/do when the timing/choke/idle speed aren't set right.
Any idea's?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-16-2007, 06:40 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: ignition problems
its either a faulty ignition switch or somehow there is a short supplying power the the HEI
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
