Old 12-16-2007, 07:32 AM   #1
TotalChevy1
TotalChevy1's Avatar
Gas cap options
I've been looking for a custom cap and think I may have found one, but somewhere I thought I read that 67-71 uses a different cap than the 72's, but this cap is listed on ebay and it say 67-72. Can anyone tell what the differences may be if any. I like the bowtie on the cap, but have had a hard time finding any.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 12-16-2007, 08:57 AM   #2
GMCBubba
GMCBubba's Avatar
Re: Gas cap options
i dont' know the differences, but i did pick up a shiny plain jane cap from autozone. very cheap, very easy, in stock
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 12-16-2007, 09:11 AM   #3
TotalChevy1
Re: Gas cap options
That's what I currently have but was looking to take it to the next level. I just can't rember what made the 72 different than 67-70. I'm not sure if it had to do with emmissions, because if it does I may be able to use, my truck didn't come with any emissions except PVC valve, no cat or air pump
Old 12-16-2007, 11:13 AM   #4
TotalChevy1
Re: Gas cap options
ttt
Old 12-16-2007, 11:13 AM   #5
Olden Days
Living In The Past
Olden Days's Avatar
Re: Gas cap options
I believe the difference is that in 71, 72 with the emissions stuff added they used a non vented cap. prior to that would have been vented.
I just found that auction. That is a nice looking but spendy cap. His description states it goes up to year 70 so I would assume it is a vented cap
Olden Days is offline   Reply With Quote
Old 12-16-2007, 11:42 AM   #6
TotalChevy1
Re: Gas cap options
Your right ..it is a little on the expensive side. Would there be any side effects with the fuel system, if one was used on a none vent system.
Old 12-16-2007, 11:49 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Gas cap options
All these trucks came with emissions control, every one built.
In 71, all trucks had a return line and charchol canister, and required a different cap from 70 and older. I *think* the older ones were vented, and the later ones were not. That, or the other way around.
Old 12-16-2007, 12:15 PM   #8
TotalChevy1
Re: Gas cap options
Is the canister at the fuel pump? there are two fuel line to the fuel pump. Is the purpose of the cap to keep the system under presure? If so, what would happen if you used a vented cap?
Old 12-16-2007, 01:04 PM   #9
Longhorn Man
Re: Gas cap options
i think the canister is in the fenderwell or something. Never bothered looking for it.
I *THINK* if you used a vented cap, then the stored fumes in the charchol canister wouldn't get sucked out properly?
If that's not right, than I have no clue.
Old 12-16-2007, 01:07 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Gas cap options
Several years ago, Custom Truck magazine had an article that was intended to showcase the options for our trucks. One picture showed a stock gas cap, the stainless steel version, and stated that it was very rare to see one due to so many of them getting lost at the filling stations over the years. I still have mine but replaced it on 9-11-01 with a locking NAPA cap.....call it panic at the time due to the uncertainty of the moment.
But they said stock stainless gas caps were rare. Geeze, whodathunk?
Member Nr. 2770
Old 12-16-2007, 01:38 PM   #11
Longhorn Man
Re: Gas cap options
99% of the ones you see today are chrome, not stainless
Old 12-16-2007, 01:55 PM   #12
68caliRat
Need a bigger hammer..
Re: Gas cap options
When you say "everyone" I think smog pumps and cats, mine is stock(been in the family almost since new, and only has a PCV. Which runs to the spacer between the carb and air cleaner. Other than that...NADA.
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 12-16-2007, 02:21 PM   #13
Longhorn Man
Re: Gas cap options
the air cleaner with snorkle is a smog item
the PCV
The hose going to the carb from the valve cover
the ECS crap
the heat riser leading to the air cleaner from the manifold
All these are emissions control items.
Smog control began in 64 in cars... I think started on GM trucks a few years later.
Old 12-16-2007, 02:29 PM   #14
68caliRat
Re: Gas cap options
Must be, I just don't see how it would significantly reduce the emissions from my truck...seems like a waste..
Old 12-16-2007, 03:22 PM   #15
Olden Days
Living In The Past
Olden Days's Avatar
Re: Gas cap options
The return line and charchol canister was the "added" emissions I was talking about, which is why it needs the non vented cap.
TotalChevy. If you have to pass an emission test it wont pass with a vented cap but otherwise you can run it
Old 12-16-2007, 03:40 PM   #16
TotalChevy1
Re: Gas cap options
We'll I just keep the other cap for emissions. I've been doing a little reading and the general opinion is all 72's came with emissions. When I came home I checks and this truck never had a charcoal canister, the fue tank doesn't even have the lines on it. There no signs the tank has evey been taken out. The orginial owner never changed anything on this truck, so I trying to figure this mystery out. All it's had is a PVC....no cat, no air pump....could this be
Old 12-16-2007, 03:45 PM   #17
TotalChevy1
Re: Gas cap options
How do you determine if they are stainless, my has a shine to it, but when you us a metal cleaner it turns the rag black
Old 12-16-2007, 07:05 PM   #18
70c10
67-72 Addict!
70c10's Avatar
Re: Gas cap options
I recently put a brand new 71/72' cap (didn't realize it) on my dad's 70' and it wouldn't run!. I started chasing my tail because I couldn't figure out what the heck was wrong with his truck. I then remembered that the caps were different and verified it in a parts catalog. I put his old cap back on and the truck roared to life! Be careful and keep this in mind in case this happens after swapping caps!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-17-2007, 09:23 AM   #19
Longhorn Man
Re: Gas cap options
that would be stainless then
