I have a block I am trying to confirm a decode on it can any one help? It is a four bolt main block 350 and it has the following stamped numbers:
F0413CKB & 12S253152 I get this from the books I can find: F=Flint 04=April 13=13th day of month C=? K=? B=? 1=Chevrolet 2=1972 S=St. Louis 253152=The VIN number The CKB code decodes as 1972 350CID 165HP 2BBl going into an AB car line. The "S" decodes as a St. Louis built car which as I understand it was only the Corvette plant which built only 350 4 barrel engines. So what am I missing? |
gearhead
Re: Decode engine block numbers?
try this,( http://www.nastyz28.com/chevy-engine-code-stampings.php )im not sure if it has what your looking for but it may help
2003 GMC Z71 Daily driver ![]() 1982 Chevy 2wd short bed, project, ![]() boxerdra@hotmail.com ![]() |
Right turn Clyde
CKB 72 350 Chevelle 165 L-65 Power Glide 2-Brl
CKB 73 350 Nova 175 L-48 Manual 4-Brl CKB 73 350 Chevelle 175 L-48 Manual 4-Brl CKB 73 350 Camaro 175 L-48 Manual 4-Brl CKB 74 350 Nova 185 L-48 Manual 4-Brl CKB 74 350 Camaro 185 L-48 Manual 4-Brl CKB 77 350 Impala 170 LM-1 TH 350 4-Brl CKB 88 305 Impala 150 LG-4 700R 4-Brl
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
it is going to be interesting I'm planning on using it as a base for a 383 with about 425 horses.
Mad Scientist
Any 350 block will do that with ease.
![]() 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
