Old 12-16-2007, 11:24 AM   #1
Richard Dobson
Auto Steering column removal?
I started removing my atuomatic steering column without asking any questions, so here's where I am. I have removed the rag joint from the steering sector, I have removed all the brackets under the dash, I have removed the bracket from the firewall. Now how do I get it to go thru the fire wall. The automaic levers, do they have to be removed, because they are going to be difficult to get thru the slot. I did not remvoe the steering wheel either, do I need to? Help please. Thanks
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 12-16-2007, 11:45 AM   #2
nightmare
nightmare's Avatar
Re: Auto Steering column removal?
I don't think that you can remove the automatic levers without taking the column apart. You should be able to tilt it towards the passenger side to remove it, or rotate the column to where the levers are on top. It should then slide right out. There's no need to remove the steering wheel.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-16-2007, 01:16 PM   #3
corn
I took mine out without removing anthing. Cant remember how I did it though, just turned it until it came out I think. You will have to unhook the linkage from the end of the column though...
corn is offline   Reply With Quote
Old 12-16-2007, 01:26 PM   #4
sick69
sick69's Avatar
The hole in the fire wall has a teardrop shape to it. Turn the levers down toward the smaller end of the opening and pull the column though. The rubber grommet at the firewall should come out with the column. May be alittle wiggling involved.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-16-2007, 01:47 PM   #5
68SHORTBOX
68SHORTBOX's Avatar
Once you have taken apart the rag joint, the under dash brackets and the firewall seal you should be able to remove it from the cab side with little or no problems. I don't think it will go the other way throught the firewall, but I usually take the path of least resistance. I could be wrong it has happen before
68SHORTBOX is offline   Reply With Quote
