12-16-2007, 11:36 AM | #1 |
c notch install ???'s
I'm looking at doing a 6/5 drop
3" drop spindle 3" drop coil 5" flip rear belltech drop shocks all round Will I have any turning problems?? Also those of you who have done a c-notch can you walk me through the install process. With a 5" flip kit how much travel will I have with out the notch. Thanks for your help. |
12-16-2007, 02:34 PM | #2 |
67-72 parts collector,
Re: c notch install ???'s
Check out the FAQ (frequently asked question) section http://67-72chevytrucks.com/vboard/s...d.php?t=262547. This has alot of answers to MANY questions. There is a c-notch post for the 67-72 trucks. But for the 73-87 models look here.http://www.73-87.com/7387garage/chas...n/csection.htm
12-16-2007, 03:15 PM | #3 |
Chevy Truck Addict
You will probably want to flip those numbers around. Stock, the trucks sit about 2" higher in the back so most folks do a 2/4, 3/5, 4/6... you get the idea. If you dropped the front 6" and the rear 5" it would give you about a 3" rake. That might be what you're looking for but the a$$ end is going to sit considerably higher than the front. As far as rear travel goes, without a notch you probably won't have much more than a couple of inches.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
12-16-2007, 07:33 PM | #4 |
Cruzzzn' Vet
What size rim and tire you running?
With a Flip kit a C notch is not mandatory(24yrs without one on mine) What's the rim BS ? F/R |
12-16-2007, 10:47 PM | #5 |
I have mine dropped with all belltech parts like spindles/springs and flipkit and removed two leafs.I didnīt install the c-notch and even with the factory bumpstop the ride is nice.Ok- when hauling weight comes into play the bumpstops lay on the axletube but they are about 3 inches high!
I think iīm lowered 4" in front and about 6" in the back and itīs a longbed.
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ī81 GMC C 10, Spanish Red |
12-17-2007, 04:21 AM | #6 |
Spear and magic helmet!
Malo83,
Just out of curiosity, why does it matter what size wheels/tires you're running as to whether you'll need a c-notch or not? |
12-17-2007, 06:42 AM | #7 |
You would think it would sit higher in rear but I'm 1" higher in the front. I don't know if wrong size coils were used in front but rear is all new with no mods. So doing the 6/4 drop will give 1" nose low when done.
I'm running 275 60r 15. I don't know rim size but the bottom ball joint rubs just the slightest bit "the rubber boot" I have a polished spot around the inside of the rim. |
12-17-2007, 07:48 AM | #8 |
Cruzzzn' Vet
KTW, I wasn't refering to the C notch when I asked about the rim and tire size, sorry for the confusion, I was thinking about the front end wheels with a 6" drop it's gonna be tight on the rim and tire package.
12-17-2007, 01:30 PM | #9 | |
Flat Black, & Chrome!
12-17-2007, 01:39 PM | #10 |
correct from ground to top center of wheel well. Strange look to it with larger space in front.
12-18-2007, 03:58 AM | #11 |
Ah, OK. That makes more sense, then. Thanks
