12-16-2007, 02:16 PM | #1 |
linkage help 4l80
This is question is for the guys that have done the new egine swap(5.3 4l80). My question is how do you shift into gear. Do someone make a linkage kit or do you use the stock linkage. I had the stock linkage working for a while but when I would drive it I would have to hold the sifter from dropping to a low gear.
12-16-2007, 02:54 PM | #2 |
Re: linkage help 4l80
I don't know about a 80 but I used the stock shifter on my 60 with no problems.
12-16-2007, 05:53 PM | #3 |
Try this kit from Kugel....http://www.kugelkomponents.com/produ...shiftkits.html
12-16-2007, 07:20 PM | #4 |
You can use the stock linkage or the one from Kugel. I have a new Kugel linkage in my shop that I would sell for cheap.
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
12-17-2007, 06:04 AM | #5 |
The Lokar kit works great!
12-18-2007, 08:48 PM | #6 |
Thank you guys for the help do you have part# for the lokar part thanks
12-19-2007, 03:12 AM | #7 |
Here's some info on Lokar. I used the rod type cause it is fully adjustable & easy to install. I got mine cheaper than here though. If I remember where I got it, I'll let you know. I only paid around $47 for mine. That was 2 years back.
http://www.julianos.com/lokar_column.html
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 12-19-2007 at 03:13 AM. |
12-19-2007, 08:53 AM | #8 |
If you go with the Kugel you'll need the long rod 17"-23". It's all stainless and fit's TH 700R and 4L80.
