Old 12-16-2007, 04:12 PM   #1
cowboymike51
trany help!
i have a 72 3/4ton gmc 4x4, now it is hard as heck to get out of park and into reverse or drive, then its hard as heck to get back into park. now it didnt start doing this till today but i havent drove her for about a month and this is the first time this year in the cold. could it be that the tranny is low on fluid i havent checked it yet, just kept her parked for the day becuase it is realy cold here right now. any advise is welcome thanks.
cowboymike51 is offline   Reply With Quote
Old 12-16-2007, 04:21 PM   #2
kxnomore
kxnomore's Avatar
Re: trany help!
It could be your column. There's a mechanism that makes you have to pull back on the shifter to slide the shift link over a raised portion of the column. If you look on the engine side of the firewall there should be a spring just in front of a triangle like bracket clamped to the column. At the end of this bracket is a rod going down to your frame and tranny. Try shooting this bracket and nearby linkages liberally with WD-40 while someone pulls back and forth on the shifter... It should move freely back and forth or up and down on the column.
kxnomore is offline   Reply With Quote
Old 12-16-2007, 04:33 PM   #3
brianthelion02
Overdrive club
brianthelion02's Avatar
Re: trany help!
The truck needs some warm AZ air,send it this way!!!!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 12-17-2007, 12:07 AM   #4
JimKshortstep4x4
Re: trany help!
Be sure to shoot some penetrant into the upper column by spraying through the shift lever hole as that part of the shift column can stick, also.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
