Old 12-16-2007, 06:14 PM   #1
62 C60
62 C60's Avatar
'62 2 ton
Well, let me start off by saying I'm 14, and a freshman in high school, and this truck will most likely be used for my senior project.
Its a 1962 Chevy C60 (these are 2.5 ton right?) with a straight 6 and a Clark? 5 speed and a 2 spd rear axle. It doesnt have breaks and the axle doesnt shift. (its runs on vacuum, so, maybe a line is unhooked/rotted?) so its not drivable right now. but the best part is, i paid $100 for it and just had to drag it out of the holler it had been sitting in for about 10 years. and i only have another $100 in it.
my plans are:
Engine/drive train:
first things first, POWER STEERING!
sticking with the straight 6. except its getting a bigger one......when i get the money of course (read: CUMMINS)
probably keep the 5 spd thats in it.
keeping the 2spd axle
Exterior:
Im thinking red and white 2 tone.
Black steel flat bed w/ built in goose neck.
Interior:
probably painting the dash white
full autometer gauges
cloth bench seat. or maybe a 20/60/20 (a bench with captains chair backs and a folding console in the middle.)
Custom Stuff:
thinking about grafting another 62 cab onto the back and making it a crew cab.
tilt nose? (still iffy, leaning twards no on that one though)
yeah i know so, this is the only one i have right now. and its about 2 years old.
like the mountain dew bottle gas cap? thats rat rod material right there lol
Also, can anyone tell me what transmission this is if i show your the shift pattern? its really funky.
^^pic credit goes to 1969 GMC
P.S.
sense im 14 and dont have a job, i probably wont be doing much to this until around this summer.
-Jake
62 C60 is offline   Reply With Quote
Old 12-16-2007, 06:37 PM   #2
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Re: '62 2.5? ton
I might suggest looking for an older 1 ton frame. It will ride alot better, you can keep the 2ton look, and not be ridiculed at the local teen hangouts.I found an 84 1ton g30 box van with 49,000 miles for $300.00 P/S, P/B, A/C. I scrapped the box and am putting my 65 3/4 ton cab and doghouse onto it for my company shop truck. Good deals are out there, and you have time. Good luck whichever way you decide to go. Jerry
ClassicAutoResto is offline   Reply With Quote
Old 12-16-2007, 06:41 PM   #3
62 C60
62 C60's Avatar
Re: '62 2.5? ton
I'm not too concerned about the ride because I am also building a 4x4 trail truck so this will be my tow rig. Im not worried about being made fun of when I drive this, either, as it will not be a DD. I have a 93 full size blazer for that.
Old 12-20-2007, 02:59 PM   #4
62 C60
62 C60's Avatar
Re: '62 2.5? ton
I've been thinking about building the engine that is in this truck now. But i can't find anyone who sells performance parts for these old straight 6's. Does anyone know of some websites I can check out and get some prices?
Old 12-20-2007, 04:28 PM   #5
68K20 x Drill
Re: '62 2.5? ton
Ebay might turn up an Offenhouser 4bbl intake, and DIY header kits only cost a little more than a header that is premade
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-20-2007, 04:38 PM   #6
62 C60
62 C60's Avatar
I planned on making my own headers. And I may attempt a 4bbl intake. But, I'm looking more towards internal stuff. Like, bigger pistons, a more aggressive cam, and a stroker crank if anyone makes one.
I'm comfortable doing head work. (3 angle, port & polish, ect.) I've had plenty of practice with this on various four wheelers and dirt bikes I used to have.
Old 12-23-2007, 07:38 PM   #7
Captainfab
60-66 Nut
Re: '62 2.5? ton
I would say first you need to confirm which I6 you have. If it's the original engine I'd guess it's a 235, which will limit the selection of performance parts. One place to check would be Clifford Performance, for an intake, valve cover, and possibly a header. For a cam you might check with Isky....they've been making cams since I6's were popular back in the 50's and 60's. As for the rest I'm not sure, I'd have to think about it for a while since I'm not really into the I6's. Try posting in the engine forum of this board. I remember seeing a member on here that appears to be into I6's....might find him over there.
As for the tranny, you've probably got the same one I have in my '63 C60 and I was thinking it was a Spicer....I'd have to look to be sure.
Good luck on your project....should be cool when you're done. It's good to see someone your age interested in tackling a project of this size.
Old 12-24-2007, 02:00 PM   #8
62 C60
62 C60's Avatar
Re: '62 2.5? ton
thanks for the info. Im thinking it is a 235. but with the trans, i have no clue. my dad rebuilt about a year or two ago im sure he knows what it is.
Old 12-24-2007, 03:00 PM   #9
62 C60
62 C60's Avatar
Re: '62 2.5? ton
i was just thinking, this summer i was trying to get this running and i remember seeing a sticker or something on the carb i think that said it was a Jasper rebuild. so, i have no clue what it is. when the PO put this in they may have upgraded it a bit?
Old 12-24-2007, 05:02 PM   #10
ClassicAutoResto
Rust Buster
Re: '62 2.5? ton
Assumption is the mother of all screwups........the numbers are stamped into it, you just need to find them. Most all numbers can be found in a google search if put in properly. That is how I find parts for mine and my customers' rides. There are many decoder sites and if you need help, let me know, or give me the numbers when you find them, and I have a carb rebuild book at my shop with all the manufacturer numbers and current availability for parts. Just let me know and I will be glad to help. Jerry
Old 01-06-2008, 12:14 PM   #11
62 C60
62 C60's Avatar
Re: '62 2.5? ton
I took some better pics today.
I don't know if this truck was orignaly white, red, green, or rust?
Drivers side
Passenger side
Interior. That new car smell has been replaced with mouse urine. It stanks somethin awful.
Believe it or not, this has only rolled over once. 169,484 original miles.
-Jake
1962 C60 261 I6 5+2spd I like to be different
Interior- Puke green dash, brown vinyl seat from an 87.
Exterior- Rust
1993 Full Size Blazer 4x4 Stock for now.
If you have a truck everyone is your friend. When they need to move.
Old 01-06-2008, 12:46 PM   #12
62 C60
62 C60's Avatar
Re: '62 2.5? ton
Heres some pics of the engine compartment. The engine mounts are straight across so that rules out a 292.
^Those numbers are- 3838350 and under it it says GM 3. (I think thats what it said?)
-Jake
Exterior- Rust
Old 01-07-2008, 04:11 AM   #13
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
Re: '62 2.5? ton
ill bet that thing aint no rocket hah but with the plans u have for it she will look good escicially the crew cab thing... nice
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 01-07-2008, 08:47 AM   #14
62 C60
62 C60's Avatar
Re: '62 2.5? ton
Oh believe me, its definitely no rocket. Last time I drove it it took almost a 1/4 mile to get up to 45 mph.
-Jake
Exterior- Rust
Old 01-07-2008, 09:08 AM   #15
Stepside65
Still Truckless!
Stepside65's Avatar
Re: '62 2.5? ton
Jasper rebuild means that motor comes from Jasper Motors out of Jasper, Indiana. It is most likely stock as much of their rebuilds are. Also a good site to go to for all things I6 is Stovebolt.com Those guys should be able to answer all your motor questions including performance parts. Best of luck!
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 01-07-2008, 09:20 AM   #16
1969k10stepside
Re: '62 2.5? ton
62 C60,There is 2 60-66 C40-c60s in the junkyard down by me.If you need any parts send me a pm and I'll see if it has anything good on it
1969k10stepside is offline   Reply With Quote
Old 01-07-2008, 09:30 AM   #17
greg64
greg64's Avatar
Re: '62 2.5? ton
Jake, I ran your casting number through the list at Inliners.org (http://inliners.org/casting/numbers.html), but I didn't find it. I can say (as an old inliner myself) that you're not dealing with the "newer" 194/230/250/292. You've got either a 235 or a 261. Look for more casting numbers on the side of the block near to the distributor.
Looks like a neat project, though. I wish I had the space for something that size. Good luck, Greg
Oh, and have a look at http://www.patricksantiquecars.com/chevrolet.htm
greg64 is offline   Reply With Quote
Old 01-07-2008, 09:40 AM   #18
62 C60
62 C60's Avatar
Re: '62 2.5? ton
Thanks. I knew they had something on there site about casting numbers but I haven't checked it out yet.
K10- Where are you at in Southern, Indiana? I could use a set of front fenders and a hood. Of course, I have to get the money first.
There is a guy about 6 miles from my house that has a BUNCH of old Chevys in his yard/field. He has a 61 truck like mine sitting right by the road and it looks to have no rust. I may try and talk him out of it. But, I have no clue what it is. all I know is, its a 61 C+C and it says Viking on the fender.
-Jake
Exterior- Rust
Old 01-07-2008, 11:14 AM   #19
62 C60
62 C60's Avatar
Re: '62 2.5? ton
I just went out and checked the numbers again. and they are 3836850. not 3838350. I googled the new number and from THIS site, I found out that it is a 261.
-Jake
Exterior- Rust
Old 01-07-2008, 12:04 PM   #20
1969k10stepside
Re: '62 2.5? ton
I'm in the Linton area.That guy doesn't have any newer (67-72) trucks in his yard,does he?
Old 01-07-2008, 12:13 PM   #21
62 C60
62 C60's Avatar
Re: '62 2.5? ton
Linton eh? I'm down around there frequently. My grandparents have a 300 acre farm right outside Worthington.
I think he has 2 or 3. I'll take some pics next time I drive by there.
The only problem is, there is all these trucks and cars sitting out there and there is a house trailer right next to them, that I dont think he lives in though. But for the past 9 years we have lived here, every time you drive by the place, if you look in the window of the room closest to the road, there is a single light hanging form the ceiling and I have never seen it off.
-Jake
Exterior- Rust
Old 01-07-2008, 01:11 PM   #22
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: '62 2.5? ton
That is a way cool project you got going there....that thing would make a SUPER car hauler.....stretch the frame...and put a nice long bed on there...
Your plans for it are way cool, though !!!!
Good Luck !!!
Later....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-07-2008, 02:41 PM   #23
Stepside65
Still Truckless!
Stepside65's Avatar
Re: '62 2.5? ton
What part of Central indiana are you from Jake? I'm from the terre haute area originally. Just got displaced here in the desert cuz of the military.
~James
Truckless
Tutor Et Ultor
Old 01-07-2008, 07:54 PM   #24
62 C60
62 C60's Avatar
Re: '62 2.5? ton
I'm about 10 miles south of cloverdale.
-Jake
Exterior- Rust
Old 01-07-2008, 08:00 PM   #25
62 C60
62 C60's Avatar
Re: '62 2.5? ton
So, I just got the trial version of photoshop and was playing around with it. And came up with a general idea.
-Jake
Exterior- Rust
