12-17-2007, 06:09 AM | #1 |
Chevy steering column
Does anyone know if the shift indicator and shift housing from a 71-72 truck will fit a 76 chevy van tilt steering column? They look identical. I just dont want to spent 500 dollars on a new tilt steering column.
1956 chevy 3100 short bed small window- TCI mustang II with 2" drop spindles, smoothed firewall, CPP brake booster, chevy 10 bolt with disc brakes, c notched. http://67-72chevytrucks.com/vboard/s...d.php?t=217757 Last edited by samcrf450; 12-17-2007 at 06:10 AM. |
12-17-2007, 07:45 AM | #2 |
Re: Chevy steering column
Yes it will. They are the same column. I used a Chevy van column in my 72 truck, The housing is the same.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
12-17-2007, 11:38 AM | #3 |
Cool thank you very much
1956 chevy 3100 short bed small window- TCI mustang II with 2" drop spindles, smoothed firewall, CPP brake booster, chevy 10 bolt with disc brakes, c notched. http://67-72chevytrucks.com/vboard/s...d.php?t=217757 |
12-18-2007, 01:26 PM | #4 |
No problem.
12-18-2007, 07:03 PM | #5 |
You can also buy just the indicator for your column. Summit
racing sells an indicator that will work on most columns. |
