Old 10-13-2002, 01:01 AM   #1
COBALT
COBALT's Avatar
Unhappy Getting the bolts out of the rear springs...
Ok, both lower bolts broke. One allowed me to get the spring loose while the other just sits there mocking me.
The uppers are not moving period. The nuts inside the frame chanel are so rusted they won't even take a wrench. How the hell am I going to get these loose? If they tops were loose at least I could mess with the lowers on a bench, but not while they're still attached to the truck. Any ideas or suggestions? I'm thinking about pulling out the whimpy dremel tool and trying to get in there with a grinding wheel. That will take about 1000 years.
:P
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-13-2002, 01:48 AM   #2
cableguy0
sounds like u really need to look into a torch setup. its the fastest and easiest way to get rid of bolts
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-13-2002, 02:30 AM   #3
Alaskan
Truck'n the alcan
Alaskan's Avatar
Best way of removing old rusted bolts is with a cutting torch. Could probably rent a cutting setup from a tool rental place. If you have never used one practice on some scrap steel. Takes about 10 seconds to blow one off. Have a spray bottle or fire extinguser handy.
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 10-13-2002, 01:30 PM   #4
hanssolo
hanssolo's Avatar
Die grinder with a metal cutting disc will cut off bolt heads and nuts pretty fast also. My die grinder is one of my most universal tools. Next week I get to port a new set of heads with it. Yea!
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 10-13-2002, 01:55 PM   #5
crazy longhorn
Fabricate till you "puke"
Here in Illinois, the "smokewrench" is my best friend when working on the bottom side of these old vehicles.
crazy longhorn is offline   Reply With Quote
