Old 12-17-2007, 06:36 AM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
help with hot start
Here's the problem. When I start my truck in the morning, It starts no problem. I need to give the gas a tap or two to get it running good, but after that it runs fine. I can drive for a while with no problems. After I shut it down, if I try to start it within 10 minutes it will start right up. But, if I leave it sit for an hour or two, i will turn over but won't start. There is fuel going to the carb. It will eventually start with a good amount of gas, just not like before. I look in the fuel filter and there is little to no gas in the filter, almost like the gas is running back down to the pump. I don't see any leaks or cracks in the line or fuel pump. Any ideas on what would cause this?
Thanks in advance.
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 12-17-2007, 06:48 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: help with hot start
I have one of the glass filters on my truck. I could smell gas, but didn't think anything about it. On a whim, I replaced my "rubber" fuel lines from the pump to the carb. Smell is gone, and it starts right up. It had fuel in the glass before, but it wasn't full of fuel. I don't think you are getting enough gas after it sets, just like mine did.
Member Nr. 2770
Old 12-17-2007, 07:11 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I have seen small pin holes or undetectable cracks let fuel drain back.The carb float bowl should still have enough fuel to start the engine though.I would check or just change fuel lines and filter and maybe check the fuel pump.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-17-2007, 07:28 AM   #4
68gmsee
Active Member
68gmsee's Avatar
My guess:
The fuel is being drained from the bowl area of the carb into the intake causing a flooded condition. Cranking it for a length of time will usually restart it.
You say that fuel is getting to the carb after it sets and that it cranks right up after sitting overnight. The only thing that comes to mind is a flooded condition preventing it from starting right up.
I would take the carb apart and give it a good cleaning with carb cleaner and maybe replace the needle valve.
68gmsee is offline   Reply With Quote
Old 12-17-2007, 07:52 AM   #5
phanatic32212
The thing is it just started doing this. I haven't changed anything to cause it. I can see through the filter and shortly after I shut it down, I can see bubbles coming up through the line and into the filter.
Or Give Me DEATH
Old 12-17-2007, 07:54 AM   #6
wibilly
wibilly's Avatar
smell your oil if it's getting flodded that much that often the oil would become contaminated and lead to an early death. my guess is, it is caused bby one of two things, one is evaperation from a hot intake and improper gasket or heat shield, two is no ckeck valve in the fuel filter which the filters in the fuel inlet in rochester carbs had. you could also have a weak fuel pump compounding the problem
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-17-2007, 08:18 AM   #7
cdowns
cdowns's Avatar
what do your spark plugs look like
Old 12-17-2007, 10:05 AM   #8
phanatic32212
I checked the oil, nothing out of the ordinary. Aside from a little carbon buildup, the spark plugs look alright. The engine has been running rich for a while now, which explains the carbon. With the glass filter that I have, when I shut off the engine, I can see the fuel slowly drain back towards the pump. This has never happened before, it has always held fuel in the filter. Is this my problem and what would cause that? Thanks again for all of the quick responses.
Or Give Me DEATH
Old 12-17-2007, 11:14 AM   #9
cdowns
cdowns's Avatar
theres a piece of rubber hose under the cab on passenger side where the fuel line from the pump connects to the line from the tank check that for crackjs
Old 12-17-2007, 02:09 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Since you don't suspect flooding I'd go with the fuel pump. They're cheap and easy to replace.
If you haven't replaced it in a long time, I would do it anyway because the diaphragm can go bad. It will crack and allow air in causing fuel to drain back down. Also will cause the pump to be weak as wibilly mentioned. I had mine do the same thing on my 69 a few months ago.
The thing that's got me thinking flooding is that you can start it right up except when it's hot. If the spark is there then it usually indicates one of two things. Flooding (fluid dripping into the intake) or no fuel in the carb bowl. Still could be caused by needle valve sticking or dirt/grime in the bowl.
