3 point seatbelt mounting
Has anyone put 3 point seatbelts in there 67-72 chevy? I would like to put shoulder harness seatbelts in my 68 and was wondering if there is a manufacturer that makes a direct bolt in using the original mounting points? Would prefer not to make new holes, I think it would be just plain easier with direct bolt ins.
That's right, it's Copper!!
Re: 3 point seatbelt mounting
Try Early Classic, thats where I got mine. Great people and great service.
www.earlyclassic.com |
upgrading to an older model
I havn't done mine yet but I think I've fugured out what I'm gonna do...I'm going to take a peice of 1" square tubing cut it the width of the cab minus a couple of inches, miter the ends, all that pretty stuff. Remove the top bolts of the gastank, drill holes in the square stock so that bolts will go through it and into where the top bolts for the tank are. Then get my seats right, figure out where the shoulder straps need to be mounted, mark the square tubing, REMOVE it, weld bolts onto the tubing to use as the anchor point, paint it all up to match the interior and bolt it back in. As for the lap belts I'm just gonna use the factory bolt holes. Ya think it'll work?
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
fugedaboutit
![]() Join Date: Mar 2005
Confused to why you would have to do all that.. from what Ive read they sell direct bolt in units for a little over 200$. There should already be a threaded hole in the pillar.. you may just have a plastic cap over it now. Others have also pulled seatsbelts out of newer trucks but you have to bang the retractor mount with bfh to get it to fit when your tank has not been relocated.
Currently truckless ![]() |
My reasoning behind doing it this way is that I want the shoulder straps to come through my seat so they need to be mounted directly behind the slots. I'm using racing seats
In addition I'm figuring $10 for the square tubing, $3 worth of bolts and a can of paint...$15 compared to a $200 kit
fugedaboutit
the kit includes the seatbelts
fugedaboutit
Brock- not trying to step on your feet at all.. just make sure you check local laws and NHRA rules (if you plan on racing) on how you go about mounting your belts. I know there is some regulation on where the mounting point needs to be, obviously higher than the shoulder. Im wanting a safer setup myself and would be interested in seeing your progress on this subject.
eric
fugedaboutit
heres the earlyclassic setup
Here's the article that I read and the direction that I used to purchase my 3 point belts. http://www.customclassictrucks.com/t...tem/index.html and the link to the belt supplier http://buckle-up.net/index.html
71 Cheyenne SWB Last edited by xmitsu10; 12-18-2007 at 06:09 AM. |
im going to use a set of S-10 belts... I have heard that they are a "bolt-in" setup. we shall see...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
chevy truck fan
i used a set from a '95 suburban & just bolted them into the stock holes at the top & at the bottom. they work but the angle at the base is not right & needs to be adjusted. i think that "putter" did a right up on how to install them with the adjustment... not sure though.
just my 0.02 |
![]() Join Date: Sep 2007
Not sure if these will work right. But I just bought a set off e-bay for 40 bucks. Search for 2 point seatbelt and this should come up.
Ad says he bought out a bunch of overstock... Check it out, it's a whole bunch cheaper than buying from parts outfit... |
#13 | |
These are the belts I'm looking at $69 each so $140 + 20 for hardware still only $160
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() Last edited by Brock; 12-18-2007 at 05:42 PM. |
#14 |
Got mine from www.buckle-up.com. Bolted right in.
#15 |
Picked up mine from LMC truck I think.
Unflattering picture below. Won't be needing them now that I located some late model Sierra seats w/the integrated seatbelts.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#16 |
Old member
I used a 90 model set out of a chevy truck. Bolted them right up with orignal holes in floor.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#17 |
"Trucks with Class"
![]() Join Date: Jul 2000
These are the belts we use & sell. They look to be same as ECE...just a little better price and we do provide a set of directions just for installing in 67-72s.
These are in with a set of 60/40s, but work just as well with stock seats. |
#18 | |
#19 | |
"Shoot I should have checked 1st with that Olympia guy" Sorry ! I'll be in the market for ALOT more stuff . I'll think more next time . ![]()
"I feel the need for speed!"... as soon as I am done with my nap. |
#20 | |
![]() Join Date: Mar 2000
You might want to think twice about those integrated belts. I have posted very vocally about this issue many times. Our trucks were simply NOT designed to handle the loads imposed by an integral belt seat. Bench seat floors are not even strong enough to safely support a set of factory buckets. Factory bucket trucks had extra bracing. And no factory bucket trucks are likely not strong enough for an integrel belt seat either. I do seat and belt mounting design for an RV manufacturer and have seen what a seat belt pull test can do to a vehicle floor! You do not want to be safely belted to your seat as it crashes into the dash and steering wheel shortly before you and the seat are ejected from your truck.
Saskatoon, Saskatchewan Canada |
#21 |
Freeeeee Mason...
The integrated best are fine as long as you brace the under side of the cab sufficiently.
