Old 12-17-2007, 12:38 PM   #1
bean
sealing the rain channel
this may be a dumb question but i need to seal the rain channel on my truck. I've got the seal but how wide a bead of this do you normally use? any help is appreciated.
bean is offline   Reply With Quote
Old 12-17-2007, 02:13 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: sealing the rain channel
As long as you clean out all of the grime and make sure you don't have any rust left, it's really your call.
I caulked mine with a single, thick bead and then used my finger to smooth it and curve it for the water to drain evenly out of it. I just made sure that all of the seams were covered then primed and painted it...
68gmsee is offline   Reply With Quote
Old 12-17-2007, 05:31 PM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
There is also a two part epoxy sealer that works really well. Check at your professional body shop for that product. You will also need a special application gun to apply this material. It hardens unlike the GM drip rail caulk.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 12-17-2007, 06:51 PM   #4
dan42
dan42's Avatar
I have to do that too. Clean it really, really good, because any rust left at all will grow fast - figure about every night you get standing water there, from the dew. There's a special caulk to put there, like stllookin says, you can get it at an auto paint shop.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-18-2007, 02:38 AM   #5
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
I used the 3M product, I believe it was #5803 or 5308, not sure which. But it is a self leveling sealer and does a great job. You will need the special applicator gun that some paint suppliers will let you borrow if you buy their product. If you use auto body caulk it won't stay. Here's how mine turned out...
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
