Old 10-13-2002, 09:07 AM   #1
jager69
Front brake cylinder removal
goin thru the brakes on my 69' C-10 Stepside with front drum
brakes, the rear cylinders are attached with 2 small bolts from
the backside, however the front cylinders have a 1 1/8" inch
nut /stud where the main springs on the shoes attach to, see
picture, can't budge it, even tried an air wrench, any suggestions?
was thinking of heating it up with a torch.
Mark
jager69 is offline   Reply With Quote
Old 10-13-2002, 10:40 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
An impact wrench is going to be needed. By the way, the front brake wheel cylinders are specifically for the left or the right, in comparison to the rears.
I converted to discs on my '69 C-10. I know everyone can't, won't or doesn't want to, but it sure improved the driveablility.
Get an impact tool and go for it. Heating it will help, too. There are some hand-held impact tools that you strike with a mechanics hammer, while twisting in the desired direction. What I have is a 3/8' drive, and my inch and an eighth impact socket is for a 1/2" drive. An adapter would be necessary. I don't know if anyone makes an adapter suitable for impact drivers/wrenches. A lesser quality tool would probably break....how soon is anyone's guess. Good luck.
Member Nr. 2770
Old 10-13-2002, 04:26 PM   #3
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
JAGER69 look behind the nut you should see a flat washer that's been bent up on one side.
That flat washer holds the nut on so it will not back off.I just did my brake system on my 69 so that's how I know.
By the way I only used a 1/2 inch breaker with a cheater bar, so best of luck.
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
