rubber fuel line in the cab -
Does anyone know it's O.K. to run rubber fuel line from the sending unit in the tank to the floor, and then switching back to metal fuel line on the frame? I can understand why not to run it around the motor, but in the cab, I can't see any problems. I was wondering if anyone has done this.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
its all about the +6 inches
Re: rubber fuel line in the cab -
it's not the prefered method, but at least you'll have no doubt there's a problem once it rots away.
hot cross buns
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 Last edited by dan42; 12-17-2007 at 04:33 PM. |
![]() Join Date: Jan 2005
I ran rubber from the fuel sender down to metal that ran through the floor...had a little bit of rubber from the cab to the frame to allow it to flex a little...never had any problems...
Make sure you use a grommet if its going through any sheet metal. Ive never had a problem but Im a rule breaker...
