12-17-2007, 04:23 PM | #1 |
which is better drop springs or drop spindles
im trying to drop my truck.i have a 71 c10 that im working on and i got me hands on some 3 in drop spindles and my haeds on some drop springs there 3 inchs too.i want to know with ones to go with.i dont want to go to low because i want to put some 24 inch rims on it.
12-17-2007, 04:49 PM | #2 |
Re: which is better drop springs or drop spindles
ttt
12-17-2007, 05:35 PM | #3 |
six inches is a lot to lower the front. maybe get a 1 inch spring to go with your spindles. I don't know about the 24" wheels, you might have to modify the inner fenders for clearance. These trucks look really good with a 4" front drop and 6" rear drop in my opinion. good luck.
12-17-2007, 05:45 PM | #4 |
Tot Roddin'
I think that you will be pushing it with 24's, I doubt they will fit, without extensive modification.
As for spindles vs. springs, I would always start with spindles and then go from there. The spindles will help to keep the geometry of the front suspension as close to original. By the way.... The mod's don't like it when a thread is "ttt'd" within 20-30 minutes of initially being asked. Usually they will delete that post on the thread. I saw this happen in another thread today. Any pics of your truck?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 12-17-2007 at 05:50 PM. |
12-17-2007, 06:10 PM | #5 |
i was going with a 3/5 i didnt want it to but to low
12-17-2007, 06:15 PM | #6 |
Tot Roddin'
I was planning on purchasing either a 4/6 or a 4.5/6 drop kit from ECE and then run 20X8 and 20X10 front and rear, respectively.
Anytime I've seen someone go larger than 20's they have to do either minor modification or major modification depending on the size they choose.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-18-2007, 12:26 PM | #7 |
thats no true.ive seen one with 26 inch rims
12-18-2007, 12:35 PM | #8 |
I have a radical idea!
I can't see 26's on one of these trucks unless it either had modified/no inner fenders or it sat up in the air like a 4X4/ghetto cruiser...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
12-18-2007, 12:36 PM | #9 |
Active Member
thats just goofy imho.
1969 C10 SWB /350 vortech/th400 1968 SWB build (in progress) 1969 SWB build (my son's future project) 1968 camaro yellow/white stripes (wife's car) 2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's 1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst. 350/350 (sold it ) |
12-18-2007, 03:19 PM | #10 |
[IMG][/IMG]
12-18-2007, 03:22 PM | #11 |
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
see it dont look bad at all with big rims on them Last edited by N2TRUX; 12-18-2007 at 04:01 PM. |
12-18-2007, 03:25 PM | #12 |
Active Member
What a shame!
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
12-18-2007, 03:31 PM | #13 |
wanna be 67
In my opinion its looks alot like what is hanging from the front bumper!!! Chrome nutsack!!! not my look.
12-18-2007, 03:33 PM | #14 |
whats wrong with them.
12-18-2007, 03:54 PM | #15 |
Have you tried the wheels with the stock height spindals you have on the truck now? I would do that first and check my clearance than go from there. But I would prefer spindals over springs any day.
12-18-2007, 03:55 PM | #16 |
BlahBlahBlah
Arent you going to need to raise the truck to get wheels like that to work?
12-18-2007, 04:07 PM | #17 |
with 24 inch rims and tires and the tires and rims will b 26inches tell.and like ith people useing 22 inch rims on there truck.there r no taller then some 22's
12-18-2007, 04:08 PM | #18 |
Happy to be here
Nothings wrong with them if you prefer that style. While you might find a few open minded people that will tell you looks alright, you won't find many of them here.
What does our opinion of those trucks you posted and their choice of wheels have to do with your question? You want to know what's better, spindles or springs, then you say your going to run 24's. If you are going to run 24's you have two choices, raise it or cut it up. 24" rims with the related tires are not going to clear on a stock truck. Lowering it 3" regardless of how it's done will unsure that 24's will not clear. You need to decide what's more important, a lowered truck or running 24's.
12-18-2007, 04:14 PM | #19 |
why not get a 4x4 and lift it? you don't need them spindels send them to methis is what you need
common sense isn't so common anymore |
12-18-2007, 04:30 PM | #20 |
BlahBlahBlah
Last edited by CG; 12-18-2007 at 04:32 PM. Reason: Just wasnt the same without the picture. |
12-18-2007, 04:38 PM | #21 |
Happy to be here
Now that's how a truck with 26's should look...
12-18-2007, 05:14 PM | #22 |
No way. For 24" rims to have a total height of 26" that would mean the actually tire would be 1" from the ground to the lip of the rim (the other inch is on top of the rim). The lowest of low profile tires are no where near that short. I know they look that way, but they are not 1" from the ground. You wouldn't even be able to drive it without bending them.
12-18-2007, 05:39 PM | #23 |
CG will that bad boy stear or does it run on rails? looks cool! i would have never said that 2 years ago but after seeing them on here so much they just look right. now i gotta build another one to drop
12-18-2007, 08:37 PM | #24 |
Active Member
As open minded as i can be... that still makes me want to throw up. Too bad that slammed pic isn't feasible, unless you plan on driving in a straight line all the time!
PS i hope foose didnt have anything to do with building that red truck.... check the wheels....
1969 C10 SWB /350 vortech/th400 1968 SWB build (in progress) 1969 SWB build (my son's future project) 1968 camaro yellow/white stripes (wife's car) 2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's 1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst. 350/350 (sold it ) Last edited by badchev69; 12-18-2007 at 08:38 PM. |
12-18-2007, 11:41 PM | #25 |
if i want with 24's the tires would b 275/30/24.and with my guestion i want to drop it,cause theses trucks look better drop.but i want to see one drop with 24's on it.i see u guys on here dropping them on 22's with ese.ant i wanted to try something different.people doing 22's with tell tires.im going will a bigger rim with a smaller tire.
