Old 12-18-2007, 05:35 AM   #1
1972Ryan
6 cyl. Auto changeover
I'm hoping someone can help me. I'm wanting to change my three on the tree over to an automatic. What shaft length 350 turbo is needed? My wife cant drive a stick and its her truck. She's always costing more money. I was hoping it would be motivation for here to learn......boy did that backfire!!!!!!!!!!
1972Ryan is offline   Reply With Quote
Old 12-18-2007, 06:43 AM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: 6 cyl. Auto changeover
yeah id like to know this also....although i have a weird 18 inch long trans and not a 21??
bad6772 is offline   Reply With Quote
Old 12-18-2007, 12:14 PM   #3
1972Ryan
ttt
Old 12-18-2007, 12:50 PM   #4
caja_larga
there are three lenths.. Ido not know the measurement but it is the middle. I just had one build and I am doing this conversion soon. I will get pictures and measurements.
caja_larga is offline   Reply With Quote
Old 12-18-2007, 02:33 PM   #5
Tim Christian
Tim Christian's Avatar
On this change over if you are leaving the 6-cylinder All you need is a 350 turbo with a 6 inch tailshaft. It is the exact same size as your 3-speed bolted to your bellhousing. You will be able to use the driveshaft you already have. Tim
Tim Christian is offline   Reply With Quote
Old 12-18-2007, 03:57 PM   #6
bad6772
bad6772's Avatar
hey tim what size trans???the 21 or 18 inchers...????????
Old 12-19-2007, 12:52 AM   #7
Tim Christian
I have not measured just the trans by itself but I guess it would be the 18 in. They made 3 diffrent turbo 350's a 6in, 9in, and 12in tailshaft. You would need the shortest one if you are planning on using the same drive shaft with the 6-cylinder. Now if you are converting to a V-8 it is a diffrent ballgame.
Old 12-19-2007, 01:54 AM   #8
bad6772
bad6772's Avatar
thanks tim.....any guess on how this 6cyl and auto will run? i know the 350 will take some extra ponies....but i dont know how much????
Old 12-19-2007, 04:36 AM   #9
crazy longhorn
Fabricate till you "puke"
On your 67, you will need to replace the slipyolk & shorten the front D shaft to do the swap. I agree with using the short (6" tail" 350 T), & thats a direct swap on the later trucks with the saginaw trans(7 bolt side cover). Your shortie 3 spd is a Muncie(iD by 4 bolt side cover). You can also use a D shaft from a 69-72, 6 cyl 3 spd truck that has the same wheel base as your truck. Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-04-2008, 05:25 AM   #10
1972Ryan
What is needed as far as the linkage is concerned? Is it different for a six with an automatic?
Old 01-04-2008, 05:57 AM   #11
Blue71LWB
Blue71LWB's Avatar
Ryan,
If you are running a stock intake/carb set-up you will need to fab or source a kickdown bracket. I would assume these would be tough to come by , as most 6 cyl had the manual trans.
(I copied this pic from here http://67-72chevytrucks.com/vboard/s...d.php?t=271500
Zac
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 01-04-2008, 06:25 AM   #12
Tim Christian
Hey Ryan I have the correct driveshaft and linkage for the auto. Also have a van tilt column that will work on the 6 cylinder.
Old 01-04-2008, 07:16 AM   #13
1972Ryan
I am running an Clifford Intake and Holley #4548-s carb on it and will add a header as soon as I can afford one. I will also be adding A/C when I can find a template for the holes to be cut. I'm doing the truck for my wife and want it to be driver friendly for her ability....LOL
Old 01-04-2008, 02:29 PM   #14
brianthelion02
Overdrive club
brianthelion02's Avatar
Those brackets are very hard to find,i sure do need one!!!!!!
Originally Posted by Blue71LWB View Post
Ryan,
Zac
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 01-06-2008, 03:29 AM   #15
1972Ryan
ttt........anyone know where Brian and I can find the brackets?
Old 01-06-2008, 10:39 AM   #16
lutherb69
Hello I'm in the same boat I have a 68 Surburban with MT on the floor and want it to be AT would the same go for me if I have a 2 part driveshaft? Also want to change gears at the wheel. Thanks for the time.
lutherb69 is offline   Reply With Quote
Old 01-06-2008, 11:55 PM   #17
sea chief
I would like to do this too. My big question is what about the flex plate. Will a v-8 flex plate work?
1967 K-20, 1969 K-20, 1970 C-30 dump,1971 K-20
1972 K-20, 1972 C-10, 1968 Grandprix
John Deere 350c Dozer, 3414 International backhoe
1972 International 1600 Flatbed
sea chief is offline   Reply With Quote
