Old 12-18-2007, 10:37 AM   #1
chip46wis
Trailing arm lowering block
I have a 69 stepside----trailing arm rear can I use rear lowering blocks on this?----It just doesnt seem like they would work----if so where can I get a set and how big can I go?---3in 4in?----confused here.
OR is it easier and safer to just go with lowering springs?
Thanx
chip46wis is offline   Reply With Quote
Old 12-18-2007, 10:39 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Trailing arm lowering block
moving to the 67-72 truck page
Old 12-18-2007, 10:58 AM   #3
chip46wis
NP---thank you for the up.
Old 12-18-2007, 11:37 AM   #4
jkaylor68gmc
jkaylor68gmc's Avatar
My buddy and I are working on lowereing blocks for these. I would not recommend more than about three inches. Pm me with what you need. I may be able to help. They are very easy to do and much cheaper than springs.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 12-18-2007, 12:01 PM   #5
Shane
Shane's Avatar
Yes you can use lowering blocks on your truck. You will need the blocks and longer U bolts.
I would strongly not recommend anything over 2 inches.
Shane is offline   Reply With Quote
Old 12-18-2007, 02:55 PM   #6
LONGHAIR
For safety's sake, don't use a block that would let any part of the suspension hang below the edge of the wheel. This allows a solid metal suspension part to drag the ground in the event of a flat tire. Steering and braking both suffer. So, maximum block size is somewhat determined by wheel diameter....with-in reason. You start to get a leverage issue, much like lift blocks on 4x4s, when you get too thick...I wouldn't go more than 2"
LONGHAIR is offline   Reply With Quote
Old 12-18-2007, 05:06 PM   #7
CG
BlahBlahBlah
First off I agree totally with what LONGHAIR said. I do find it amusing though whenever this subject comes up, (and it does come up fairly often) everyone posts how dangerous it can be to let anything get below the scrubline. But no one says jack when a truck is posted where the whole thing can drag on the ground, they just go off on how great it is.
Old 12-18-2007, 05:14 PM   #8
chip46wis
Excellent points well taken---THANK YOU-I will be running a 285 170 15 radial I think this should clear any problems---
Old 12-18-2007, 07:34 PM   #9
pissonNOS
senior member
pissonNOS's Avatar
i ran a 2.5: inch block for about 2 years with out any huge problems but i did take into account the things these guys are telling you about the safety
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-18-2007, 10:17 PM   #10
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Yes you can and I do. I have 2' blocks in the back. They are also easy to make if you have the time.
esll...
I'm running 295 R50X15 in the rear. I used to run 305's but BFG/TA does not make these anymore. No problems with tire rubbing.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 12-19-2007, 03:59 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=196457
Old 12-19-2007, 06:44 AM   #12
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
http://www.stockcarproducts.com/trkarm1.htm
sneakysnake is offline   Reply With Quote
Old 12-19-2007, 08:53 AM   #13
70rs/ss
70rs/ss's Avatar
Nice I just book marked that page!
70rs/ss is offline   Reply With Quote
Old 12-09-2012, 02:40 PM   #14
suxtobu65
suxtobu65's Avatar
With a 2'' lowering block, would shims be needed to maintain proper pinion angle?
suxtobu65 is offline   Reply With Quote
Old 12-09-2012, 07:31 PM   #15
CC69Rat
CC69Rat's Avatar
Shound still be ok. .. but 1-2deg would take care of it if needed. I usually run 1 deg per inch of drop. IF you have a two piece driveshaft it might be a little less of an issue. (less jumprope / harmonic vibe vs. the longer one piece. ) Just my experience..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
