![]() Join Date: May 2005
LT1 Install Project
Just picked up low mileage 94 F Body LT1, Complete harness and all accessories. Finding some good info on here and the net.
Wondering about accelerator cable, which to use? Has anyone used the factory manifolds off the Camaro? How drastic is the frame notch for those that kept the F body brackets??? Any other advice or encouragement would be great. |
![]() Join Date: Dec 2004
Re: LT1 Install Project
I've used factory manifolds from an early motor on an LT1 and it worked pretty good. You might be able to use your ram horns. As far as everything else, the best resource by far is Street & Performance in Mena, Arkansas.
![]() Join Date: May 2006
I'll be following along to see what you come up with, pls. post up lots of pics. so I can do it one day. Should be an interesting build to say the least... J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
what wiring r u going to use? Or r u going to have someone rewire the factory harness? I am starting a vortec in a 70 Blazer 4x4. Very intrested in your process!!
Too Dumb To Know Better
I have a 94 Corvette LT1 in my 72. Get a cable from a late 90's Caprice. It will work just fine. I had to cut a slot in the end of the gas pedal arm for the cable end. The Corvette manifolds didn't work for me. The manifolds of the original engine bolted up but didn't match the ports very well so I went with the S&P headers.
Good luck with the install and if you can get the 6 cyl mounts, they work great too. |
#6 | |
Kevin LFD Inc. |
