Old 12-18-2007, 04:45 PM   #1
chucks70
What rearend should I be looking for?
I have a '68 1 ton with an Eaton 4:10 dually leaf spring rearend, 4 speed, 292 motor. I have recently come across a '67 Caddy 472 motor and TH400. I want to put a rear with better gears, ie 3:73 or lower and posi. that would work better with the Caddy motor and trans. What dually rearend do you guys think I should look for?
Chuck
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 12-18-2007, 04:57 PM   #2
brianthelion02
Overdrive club
brianthelion02's Avatar
Re: What rearend should I be looking for?
You really only have one other choice,a 14 bolt!!!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 12-18-2007, 05:09 PM   #3
chucks70
Well, what all years? That would be the only choice if I did not modify. I believe I could use a newer rearend and move the spring perches inward. Dana 60, Dana 70? Chevy, Dodge, #ord. Looking for something fairly easy to find and adapt. I believe I will have to fab the drive shaft so I could adapt it to any yoke I suppose.
Old 12-18-2007, 05:16 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
how about a dana out of a 67 - 72 chevy/gmc?
Old 12-18-2007, 05:36 PM   #5
DieselEater
DieselEater's Avatar
I understood the Eaton and 14-bolt used the same ring and pinion gears??????? Not positive on this...
If so, then just buy and change to what you want...
A........
http://www.myspace.com/chevypullin
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 12-18-2007, 05:46 PM   #6
wibilly
wibilly's Avatar
desial eater i think i have read that the cariers inter change but the axels need to be shortened i have never tried it but thats how i interpeted what i read right here
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-19-2007, 03:18 PM   #7
chucks70
Do I have to get an axle from a dually or can a single wheel axle take dual wheels. I thought the duallies were a little shorter. No real old trucks with dual wheels left around here, what else can I look in, delivery vans? I don't think overall width will be a big problem because I am using a flatbed. I probably will post a WTB on the board.
Old 12-19-2007, 05:03 PM   #8
BCOWANWHEELS
a 14 bolt can go down to 3.21 gears. a dana can only go to 3.54 unless you find a dana 61 and it will go to 3.07.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
