Old 12-18-2007, 05:23 PM   #1
CAMAROSS
CAMAROSS's Avatar
Heater help?????
My heater would only get lukewarm yesterday so I put a new thermostat in today. Heater still doesnt get real hot. What next?
CAMAROSS is offline   Reply With Quote
Old 12-18-2007, 10:11 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Heater help?????
Dirty "squirrel cage"? I have the same problem too, new heater core and new water pump and 192F thermostat and still kinda-sorta okay heat, but nothing to write home about. As a comparison my Lincoln's heater can burn the skin off my fingers if set on max, damn thing does indeed get over 85F at the vents! I'm like 1500 miles away from my truck right now, but when I get home I'm pulling the squirrel cage fan and cleaning it, cause that just ain't right for the crazey cold I'll be seeing up in MI.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 12-18-2007, 11:30 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
powerflush your cooling system You may have a blockage issue in your heater core.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-19-2007, 02:24 AM   #4
mhicks
mhicks's Avatar
Mine had an issue with the door in the heater box. Under the dash take the cover off of the heater box. There is a flapper door that has a small hole in it with a piece of plastic that the control arm connects to. The plastic piece that connects to the door broke on mine. I just put the plastic piece back in where it belongs and put a small screw with a big head on it and it has been working for a couple of years.
mhicks is offline   Reply With Quote
