Old 12-19-2007, 05:55 AM   #1
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
the RIGHT STUFF
Has anyone ever used this, and what did you think?
http://www.permatex.com/products/aut...sket_Maker.htm
LOW DOUGH is offline   Reply With Quote
Old 12-19-2007, 06:14 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: the RIGHT STUFF
Right stuff is awsome, I prefer it in the caulk gun tube though.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-19-2007, 06:16 AM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: the RIGHT STUFF
Good Stuff - Big $$$ compared to the other stuff, sets up faster than most so do not lollygag around
Worked well for me, I got from a Guy that just finished up his BB 69 Camaro and is a GM Mech. He likes the stuff so I figured I would give it a try.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-19-2007, 06:39 AM   #4
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: the RIGHT STUFF
I agree. Very good stuff! I recently used it on 6.5L diesel valve covers (which use no gasket….just sealant) and a NP205 transfercase. No leaks and it didn’t require much sealant. Just a small thin layer does the job.
It is expensive! Like $13 for that bottle or something like that.
DirtyLarry is offline   Reply With Quote
Old 12-19-2007, 06:47 AM   #5
ofnaman
ofnaman's Avatar
Re: the RIGHT STUFF
I work at a cadillac and land rover dealer. We get the gray right stuff for our land rovers. I was very sceptical at first of this sealant (being a huge gm sealant fan (also good stuff)). One day we ran out of gm sealant, so I had to try the right stuff. That was 2 years ago and I have not went back to using gm sealant. Works great, I have used both the black and gray stuff. I prefer the gray, but the black is still very good.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 12-19-2007, 11:15 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: the RIGHT STUFF
The right stuff is awesome... but, on the down side, when it's time to scrape the stuff off, you'll wish you never used it, esp if you are doing it by hand.
Otherwise, I love it.
Old 12-19-2007, 03:06 PM   #7
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thumbs up Re: the RIGHT STUFF
I used the Right Stuff on my diff. in place of a paper gasket. I have also used Ultra Copper for headers instead of gaskets. I think they are great products and work extremely well.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 12-19-2007, 05:48 PM   #8
pissonNOS
senior member
pissonNOS's Avatar
Re: the RIGHT STUFF
right stuff is awesome but PLEASE read how to open carefully haha, i told my boss it was probly just like the tube stuff and to prick the top with a nail, whoops we had a huge mess but managed to get the diff cover sealed and back on, and it doesnt leak but now we have a garbage can full fo the stuff
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-20-2007, 02:56 AM   #9
68C15
blood type; Retumbo
68C15's Avatar
Re: the RIGHT STUFF
did you know RTV will cure faster if you spray it with a little water? I leaned this a few months ago when I was at a seminar put on by Permatex.
68C15 is offline   Reply With Quote
Old 12-20-2007, 04:36 AM   #10
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: the RIGHT STUFF
Someone I work with said he would spray some spray silicone on the gasket surface, then put the RIGHT STUFF on, so that next time it would come off easyer.
But I may have found my problem.
Originally Posted by 60-66 Nut View Post
LOW DOUGH, you might check to be sure you are not missing the short 3/8" bolt that goes in one of the holes on the front passenger side of the block. One of these holes(I think the top one) is drilled into the crankcase directly in line with the fuel pump push rod. Some people pull that bolt out and stick a longer one in there to hold the push rod up while changing the fuel pump. I've run across a couple leaking there before. It would only leak when you drove it, not just sitting there. Just a thought.
60-66 Nut
I don't have a bolt there. I will put one in and see what happens. I have never, in the six years i have had the motor, had a bolt there. PLEASE PLEASE PLEASE be it
Old 01-16-2008, 12:04 PM   #11
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: the RIGHT STUFF
Thanks 60-66 Nut. That was the problem. 6 years, 100 cases of oil, and pulling it out 5 times.... later and it doesn't leak anymore. WOO WOO! I can't believe it.
