Old 12-19-2007, 09:16 AM   #1
70short
Question Front wheel bearings
What is involved in doing A front wheel bearing re-pack? What all do I have to remove? 1970 C-10 2WD. Thank You!!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-19-2007, 02:15 PM   #2
BCOWANWHEELS
Re: Front wheel bearings
wheel, hub dust cap, cotter pin, 2 caliper bolts ( allen head from back of caliper, 1 top & 1 at bottom ), spindle nut, hub-rotor assy, then hub comes off, place on 2 pieces of wood ( outside bearing race up ) and carefilly instert long punch through hub on inside bearing ( not on the cage of bearing but outer race ), drive out inside bearing and seal, clean hub and old bearings very good, inspect for bearing & outer race wear-damage, put a 3 finger load of grease in palm of hand and push side of bearing into it until grease comes out opposite side ( both bearings ) put 1/4" grease completely inside hub and on races, install new seal ( CR BRAND double lip is best ) install outer bearing and put hub back on spindle, tighten spindle nut tight then back it completely off and retightem it until you feel light pressure when you turn rotor, then tighten it until you can install new cotter pin, put 1/4" of grease in dust cap and gently reinstall it, check disc brake pads before you reinstall them, put wheel back on. drive it a few miles and recheck wheel lug nuts. about 1 hr per side to do. starting fluid is great for cleaning hub & bearings. ( no smoaking )
hope this helps
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 12-19-2007, 03:24 PM   #3
68gmsee
Active Member
68gmsee's Avatar
For some reason I thought the 70's had front drum brakes.
But procedure is still the same. I just had to do mine earlier part of the summer in my 69 Chevy. Some people highly recommend synthetic grease. I used regular wheel bearing grease that I've had in a can for about 10 years.
Only thing I do different is to fill the dust cap half full before I reinstall it. Not sure why, just been doing it since a teenager.
68gmsee is offline   Reply With Quote
Old 12-19-2007, 03:53 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I bought a bearing packer from NAPA that lets you use a grease gun and drive the grease into the bearing with the hydraulic pressure that the gun generates, if you don't want to use the grease in palm method.
Member Nr. 2770
Old 12-19-2007, 03:58 PM   #5
Andy4639
Old member
Andy4639's Avatar
Factory 1970 truck does have drum brakes on the front. Disc's didn't start until 1971. Procedure is basicly the same though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-19-2007, 04:59 PM   #6
BCOWANWHEELS
sorry 70 trucks do have drums my goof. if you have trouble getting drums off you have t back brake shoe adjustment off ( hole in bottom of backing plate ) pull small rubber plug, take flat screwdriver and rotate star untill you can slide drum off.
bob
Old 12-19-2007, 05:06 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The boys have pretty well covered it. A couple of things I'd add, if you have trouble getting the drums off then just back off the adjusters that spread the shoes. The drums get a ridge behind the shoes as they wear and make it hard to remove them. Also don't put too much grease in the rear bearings or it may get hot and leak out on the axle and get on the shoes and drums giving you brake problems. My best recommendation would be to get a Haynes manual for 67 through 87 chevy and GMC trucks No. 24064. It covers any maintenance on these trucks and for $20 bucks or less it's the best money a guy can spend.
BTW are you in the Boise ANG? I was in the Battle Creek ANG.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
