Old 12-19-2007, 01:19 PM   #1
lineman33
Center hump problem
I am wondering if I swap my 72 2wd cab to a 72 4wd chassis if I will have to cut out my center hump (low hump) and bolt in a high one or if it will work both cabs are automatics if that matters thanks
lineman33 is offline   Reply With Quote
Old 12-19-2007, 03:03 PM   #2
Re: Center hump problem
Hopefully some other will chime in, but because of the transfer case, I am pretty sure you will need the high hump.
Old 12-19-2007, 03:04 PM   #3
1969k10stepside
I fit my cab on the chassis with a low hump floor but there would have to be a hole in it for the t-case shifter obviously.I already had the high hump for it so I just cut out the whole thing and mounted the tall tranny hump in there.
1969k10stepside is offline   Reply With Quote
Old 12-20-2007, 07:45 PM   #4
lineman33
I do have a high hump, how miserable is it to cut out the low hump?
Old 12-21-2007, 11:11 AM   #5
1969k10stepside
Not hard,I used a torch to cut it out,since the cab was off the chassis but it should be just as easy using a sawz-all,etc
Old 12-22-2007, 07:15 AM   #6
us111
be sure and cut out the piece all the way back under seat..
done the same thing,just cut out the high hump,
put everything together would not work.you have to have all
the way under seat.i'll see if i can find the pics
i done on it.
pics are on this page http://67-72chevytrucks.com/vboard/s...10#post1547410
us111 is offline   Reply With Quote
Old 12-22-2007, 01:42 PM   #7
lineman33
Thanks for the help now I just need to get it out from under all this snow and do it
Old 12-31-2007, 05:03 AM   #8
va_tlc
va_tlc's Avatar
yep ya gotta cut it out. we used a air chisel dang it was noisy too, and when you finish if you hear any strange noises check to make sure your transfer case isnt hittin anywhere,
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 01-01-2008, 07:06 PM   #9
Infanti
www.infantimachine.com
Infanti's Avatar
I used a die grinder with a cut off wheel ,made a clean job of it.If i remember right the floor has some stamped lines in it.Just put your high hump over it and you will see how much you have to remove.Pretty easy.
Infanti is offline   Reply With Quote
Old 01-03-2008, 07:22 AM   #10
71 super
71 super's Avatar
Lay the hump (high hump) on the low hump cab, mark and drill the holes you need to bolt the hump in then use the stamped lines in the low hump cab to cut out the low hump floor. I had to do this for my 4x4 as the original cab was junk, found great 3/4 ton auto truck trimed the hump, instant new 4x4 cab. This is not a big deal just use the removeable hump as your template and be sure to predrill your mounting hole and also remove the spot welded nuts that the bolts thread into.
71 super is offline   Reply With Quote
