Old 12-19-2007, 01:28 PM   #1
454c20
Dash pad removal
I'm looking to remove the stock dash pad in my 87 1/2 ton. How do I go about this? I've searched but have come up empty handed.
Nick
'87 1/2ton 4wd-mild 355, TH400, long tubes, 3" single Magnaflow, manual locking hubs
'88 SS-built 357, 2004r, 9.5" 3200 stall, 4.10 posi 8.5
'94 9C1-174k, built 4L60e, Hughes 2500 stall, 3.73 posi, 93oct tune, 2.5" true duals
454c20 is offline   Reply With Quote
Old 12-19-2007, 01:34 PM   #2
89 crew
Re: Dash pad removal
remove the dash bezel, remove screws located along bottom edge of pad, remove screw on passenger side of dash pad, then pull.
89 crew is offline   Reply With Quote
Old 12-19-2007, 01:34 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
5 1/4" bolts across the bottom of the dash, 1 on the passengers side end and all the bolts holding the cluster on (12 phillips)
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-19-2007, 01:51 PM   #4
454c20
Are there any up near the windshield or just on the front edge?
Nick
Old 12-19-2007, 01:52 PM   #5
Captkaos
Captkaos's Avatar
none, only clips. It has to be pulled forward to get it out.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-19-2007, 04:24 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
I just took mine off today. When removing the pad, it helps to pull up the door weather stripping near the ends of the dash pad. I had to do this on mine to make the pad slide out easier.
Pyrotechnic is offline   Reply With Quote
Old 12-19-2007, 08:12 PM   #7
1970pelle
1970pelle's Avatar
ON my 86 at one time some had installed a cheapie dash cover.It also covered up the screw on the right side.The one that you have to have the door open to see.I had to drill a small hole in the panel to remove screw.New dash panel is on the list.
1970pelle is offline   Reply With Quote
