12-19-2007, 01:56 PM | #1 |
carb help
i have a question about my carb on my 72 gmc k2500. ok well it runs fin intell you realy gun it and open all 4 barrels then its stuk at wide open throttle, so i have to shut it off and manualy close carb. now i have the stock quadrajet. so should i just get a rebuild kit and rebuild it, or would this be a good time to just get a new carb. the truck is pretty much just a goof around truck mostly in the mudd. its a stock 350 with an Edelbrock intack. so what carb would i get if i did get one. thanks
12-19-2007, 02:08 PM | #2 |
Re: carb help
Just buy Cliff Ruggles book on Q-Jets and rebuild it!!!
The Q-Jet is the best non-racing carb ever built! They did a test in four wheeler mag a while back and rated it best off road carb!!! Won't flood out and die on sharp angles....AND it works great from inline 6's to 500 HP BBC's. DON'T MAKE A MISTAKE AND BUY ANYTHING ELSE...UNLESS YOU PLAN ON RACING!!!! A..........
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
12-19-2007, 02:50 PM | #3 |
Re: carb help
I would just find out what is sticking the throttle open and fix that.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
12-19-2007, 03:05 PM | #4 |
Active Member
Re: carb help
I agree with above posts. If it's the original stock carb and hasn't been messed with it could be a sticky butterfly shaft.
I found out that the best thing on these carbs is to remove it from the engine so you can see how everything works in relation to throttle response, choke operation and fully open throttle. They have a lot of small links and cranks. As you can see by this pick... This is a newer model but should be basically the same. |
12-19-2007, 03:29 PM | #5 |
Re: carb help
thanks guys, i will probably just wait intill, the jan when my school starts agian, im in mechanic school, and then just rebuild it in class.
12-19-2007, 04:14 PM | #6 |
Re: carb help
Hey man,
Just saw that you're in CO.......Look up Lars Grimsrud on the net, he's in Longmont I think. He's one of the Corvette GURU's of the world...Maybe he'll build it for you for a decent price. A......
12-19-2007, 04:43 PM | #7 | |
Re: carb help
you do have a throttle return spring installed right?? // i'd start by looking real close at the geometry of the throttle cable .unhooking it and checking the cable first for binding or possible fraying or a kink of the cable strands then going to the actual carb linkage with throttle cable unhooked
12-20-2007, 02:54 PM | #8 |
Re: carb help
well my grandpa and I figured it out, the return spring was worn out and not pulling it back far enough to close the butterfly valve. Put a new one on and it works fine. Leave it up to the wisdom of grandpas what would we do without them. thanks guys for all the help.
12-20-2007, 04:45 PM | #9 |
Re: carb help
your grandfather sounds like a smart guy.take advantage of it while you can to learn everything and anything that he's willing to share//he wont always be there
