Old 12-19-2007, 05:16 PM   #1
Farmstore34
Farmstore34's Avatar
Question 4X4 question
Hi all,
this afternoon I took my Chevy up into the snow (72 K20, 350 w/4 speed). When I got up to where the rear wheels were spinning out I stopped and turned the hubs in, and engaged the transfer case. The front wheels would not turn, but the rear kept going. I backed up a few times, tried 4hi and 4lo but no luck. Later when I got home, I put the tranny and transfer case in neutral and engaged the hubs again. When I turned the front driveline it seemed to engage the front wheels fine. Any ideas before I start tearing into this thing? Thanks!
Colby.
Farmstore34 is offline   Reply With Quote
Old 12-19-2007, 05:22 PM   #2
DieselEater
DieselEater's Avatar
Re: 4X4 question
Maybe your hubs are wore out to the point that your hand strength won't spin past the splines, but the engine just powers through them. Take off the hubs and inspect, before you drain the diff....
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 12-19-2007, 05:43 PM   #3
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: 4X4 question
Yep, problem is probably in the hubs. Might just be sticking. Clean all the parts good & oil them up with motor oil, not grease. Grease can make them stick, especially when cold. Also, A NP205 transfer case still has the front output coupled up to the rear output when in neutral. You need to put it in 2wd, spin the front shaft & watch the knuckle U-joints. If one spins without moving the truck while the lockouts are engaged, you just found the side with the problem. If neither spin, its in the diff.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 12-20-2007, 01:34 AM   #4
1969K10
1969K10's Avatar
Re: 4X4 question
I've got one of my hubs that seams to have an attitude. So, I lock them in before I get to the point that I'm spinning tires. That way if I have to mess with my picky hub, I've got space & time. It usually takes moving the truck back or forth a couple inches... maybe your hub just wouldn't lock in where you were sitting.
I'd recommend locking your hubs in on good ground before you're stuck next time...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
