Old 12-19-2007, 07:02 PM   #1
bill8333
Alternator shorts out on dip stick
OK I know this can't be normal. I have a 1972 1/2 ton 4x4 with factory P/S and P/B. Today when I went to check the oil for the first time, (I haven't had it all that long) the dipstick hit the nut on the back of the alternator and a big spark flew off of it. Now I know I can change the belt so that it doesn't line up with the dipstick tube but this can't be normal, or can it. Anyone with a picture please send one so I can see what's wrong.
Thanks up front. Bill
1972 K-10 L/B 4x4 Matching #'s 350 4 speed from the factory. P/S P/B
1981 GMC 1/2 L/B 4x4 one owner truck. 4" lift
2004 Dodge Cummins Diesel 4x4 Q/C S/B
1986 Dodge D150 L/B 2WD
bill8333 is offline   Reply With Quote
Old 12-19-2007, 07:06 PM   #2
89 crew
Re: Alternator shorts out on dip stick
I would say your dipstick tube is twisted. sorry no pics to send.
89 crew is offline   Reply With Quote
Old 12-19-2007, 07:14 PM   #3
dan42
dan42's Avatar
Yeah, I think you can just twist the base back around. As far as I know, the tubes are just pressed in anyways.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-20-2007, 02:34 PM   #4
68K20 x Drill
The alternator is supposed to have a rubber sock over that wire, I'm pretty sure the parts store has it.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-20-2007, 06:06 PM   #5
mothertrucker424
mothertrucker424's Avatar
don't feel bad i almost do that every time i thought it was factory??
mothertrucker424 is offline   Reply With Quote
Old 12-23-2007, 03:56 PM   #6
bill8333
Thanks Guys I knew I could count on y'all for the answer. By the way It does have the rubber boot on it but the P/O installed a wire that goes to the top of the alternator looks like it was a two post pug type and he installed one wire going to the post to one side of the two plug. Is this an up grade or a F up.
Old 12-23-2007, 05:47 PM   #7
bill8333
Still need some help. I looked at the alternator today and found out that the regulator is still oon the radiator support and is still hooked up. Did the PO change the charging system over to a internal regulator ?? if so wouldn't the regulator on the support be modified in some way ??. The system is charging but the gage in the truck doesn't work.
Any ideas Thanks Bill
Old 12-23-2007, 06:37 PM   #8
PrerunnerRob
PrerunnerRob's Avatar
There are both internal and externally regulated alternators, how many wires attac to it?
PrerunnerRob is offline   Reply With Quote
Old 12-23-2007, 07:50 PM   #9
bill8333
Looks like there is only one wire on the back side of it then from there they ran a wire up to a pug on the side of it.
