Old 12-19-2007, 07:27 PM   #1
bucket
bucket's Avatar
problem with 4x4
its on a 91 1500 with 375k. its a plow truck and while plowing this weekend, front wheels quit working. lights up on the floor shifter but it makes lots of racket. even when in 2h. before this weekend, the cv joints clicked when in 4h and turning but otherwise seemed to work good.
what is the trouble shooting process? how do i identify or rule out the transfer case, joints, hubs, etc? i have never really messed with 4 wheel drives.
bucket is offline   Reply With Quote
Old 12-20-2007, 04:12 AM   #2
Re: problem with 4x4
I`d check the CVs.
Old 12-20-2007, 09:40 AM   #3
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Those trucks are notorious for failure of the 4x4 actuator switch. Borg Warner part #FWD10. They usually go for a bit over $100. Thats usually the first thing we suggest to people w/your problem BUT the noises you describe could mean something else?
johnnywagon is offline   Reply With Quote
Old 12-20-2007, 09:48 AM   #4
bucket
bucket's Avatar
thanks. it almost sounds like its partially engaged.
Old 12-20-2007, 02:07 PM   #5
bucket
bucket's Avatar
is the borg warner part number for the "updated" version? i stopped in at the gm dealer today and according to my VIN, the updated version won't work on my because i don't have the "z" code??? i asked him if they are not them same for 88 to 97 and he said ithey are not all the same and i have the earlier version.
Old 12-20-2007, 02:07 PM   #6
68K20 x Drill
jack the front up and take turns rotating each wheel and drive shaft. observe what it is connected to, listen for odd noises
I'm sorry, that is probably the last thing you want to do on snowy ground.
I would not be surprised at all at a plow breaking a half ton diff.
I believe the '4x4 posi-lock' product sells for less than the cost of 3 fancy actuators, and it seems it would be reliable.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-20-2007, 02:16 PM   #7
bucket
bucket's Avatar
i will jack up the front and have a look. i just wasn't sure what to look for since i have never worked on a 4wd. good thing is i have a 5000 sf shop to work on the equipment )
Old 12-20-2007, 06:15 PM   #8
bucket
bucket's Avatar
went down to the shop tonight and unhooked the plow so i could get the front off the ground. sure enough, the right cv is broken.
thanks guys!
for future reference: if the light indicates the front is engaged, is the actuator working? or if it does not light up, its faulty?
Old 12-20-2007, 08:36 PM   #9
Blue_71
Bloo
Blue_71's Avatar
on my 89, the 2 times the actuator has went out, the light in the floor quit working. fixed the actuator, and the light started working again
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
