I'm thinking of adding a second tank have you done it?
My 85 has the small drivers side tank (16 Gal). So I'm thinking of either adding a right side tank or puttin on a larger driverside tank or both anyone done it? What did you run into?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: I'm thinking of adding a second tank have you done it?
If yours is a shortbed and you want to use a factory tank, you can ONLY use a 16 gallon. I have put a 28gallon blazer tank in my project truck for better weight distribution.
If you add a tank you need an EFI selector valve and hoses to connect, in addition to a filler neck and a way to fill it as you won't have a fuel door...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#3 | |
Speed Limit = Floorboard
My 85 has factory dual tanks that are 16 gallon, honestly I keep a couple gallons in the passenger side tank just in case I go a little farther than I should have and thats it I hardly ever use it, its kinda a pain to fill one tank and turn the truck around and fill another, I'd rather have one bigger tank, besides the problem with a filler neck and another fuel door for ya. This is coming from someone who mostly drives between 15 to 40 mile trips to a couple differenent towns, so I'm never to far from a gas station.
1971 C20 350, 4-speed - Sold. 1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project. "Build for torque, horsepower will follow" |
I would see about putting a big Suburban or Blazer tank under the rear of the bed if you can live with having your spare tire in the bed. You could just put the filler cap in the bed floor.
We've been researching adding a tank to ours... maybe even using an S10 Blazer tank in the rear since the spare is in the bed now anyhow. The fuel tank selector valve kit from JCwhitney is part#81TS2686W for carbed motors.
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
Here is my how to page for the Blazer in a SWB pickup..
http://www.captkaoscustoms.com/blazertank.html
One shot, one kill.
Bob: You opened a can of worms with this one LOLL. You can put a larger tank in but you'll need new straps too. If you want to put in a second tank in the factory position you in for a BUNCH of work. New hangers, fuel lines, tank switching valve, wireing & punching out a hole for a fuel door. To much work. Go for a rear mounted tank. I have an 84 with dual tanks that I am restoring now. After I get her togther I'm going to see if I can't figure a way to plumb in a fuel fill cross over so I can fill both tanks at the same time from either side. Wouldn't that be cool. jim
#9 | |
The C5 has a crossover tube and it also has 2 pumps. One in the drivers tank and one in the passenger tank. The passenger side tank is constantly pumping fuel into the drivers tank.
![]() Join Date: Nov 2009
i only have a 16 gallon on one side and its not enough gas for 454. i'd like to add another 16 gallon on the other side. AND put in the big blazer/suburban 35 gallon in the rear. id use the big rear as daily and the two 16's for roadtrips in combination iwth the big rear. its awfully ambitious i know. but 16 gallons is not enough gas
1979 chevy blazer 2wd drop spindles shackles new paint wheels tires custom one of badges cut on waterjet brakes exhaust carpet 2" cowl hood window seals misc weather seals door panels crate 350 w/ 67k turbo 350 3.08 rear end gear ratio FOR SALE! http://67-72chevytrucks.com/vboard/c...ct=4838&cat=13 |
My '73 has the stock 20 gallon on one side and an aftermarket tank on the other side...still not sure how much it holds. It is setup with dual electric fuel pumps, I like that idea in case one goes bad...you can still drive home.
I still want to add a big rear tank and use that for daily driving and I'm going to add another fuel pump and a quick connector for a fuel hose, so I can use my truck like a tanker to fill up everything I have! ![]()
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
#13 |
![]() Join Date: May 2009
I`ve been thinking about ditching my dual tanks, and swapping in a rear mount Sububan one. It`d be nice to only have 1 tank to fill, and since most of my fuel system is junk anyhow....convert to TBI.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
