Old 12-20-2007, 04:10 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Help!! Transmission Wiring Harness!!
I have a 350 motor and 350 turbo tranny. I traced all the wires in the engine wiring harness and I have a wire that leads to a transmission wiring harness I think. It is wire 18DG on the wiring diagram. It has a wire connector and the has a bunch more connectors and wires. Is this needed for a 350 turbo tranny??
1971ChevyTruck is offline   Reply With Quote
Old 12-20-2007, 04:27 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Help!! Transmission Wiring Harness!!
Shouldn't have any wires going to the tranny, at least my 70 didn't have.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-20-2007, 04:36 PM   #3
cdowns
cdowns's Avatar
no those wires arent needed in fact they were normally disconnected at the dealer prior to delivery //its a half assed attempt at early emmissions theres 2relays on the firewall drivers side near steering column that were always disconnected then a sensor on the manifold and a wire going to tranny sort of in back of the shift linkage
Old 12-20-2007, 05:00 PM   #4
1971ChevyTruck
Here is a diagram of the wire I am asking about...I circled the wire..its 18DG on the engine wiring harness
Old 12-20-2007, 07:21 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
They should plug into the rear light harness for the back up lights. The other end plugs into the Backup/Neutral Safety Switch at the bottom of the steering column...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-21-2007, 12:19 AM   #6
JimKshortstep4x4
The two wires that you circled are for the backup lights on a floor shift four speed manual transmission, (light green and dark green wires).
If your TH 350 has a wire connected to it, (one wire) then it was part of an emissions system that was mentioned in a previous post.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
