Old 12-20-2007, 04:22 PM   #1
mexgrhd68
mexgrhd68's Avatar
Exclamation Car Or Truck 700r4??
I'm planning to install a 700R4 in my 68 pickup, which one is better, the car or the truck tranny?? or does it matter?? thanks ahead of time.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 12-20-2007, 04:32 PM   #2
Ackattack
Ackattack's Avatar
Re: Car Or Truck 700r4??
doesn't matter. I think the only differences are the corvette ones (they have a different servo) they may also have different converters, but that's not really the tranny.
I got mine from an astro van
Ackattack is offline   Reply With Quote
Old 12-20-2007, 04:36 PM   #3
68K20 x Drill
newer is better. if you don't use the truck for heavy work, either will be fine.
My favorite 700R ever was the stock one from my cop car...which is similar to the Corvette one.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-20-2007, 04:47 PM   #4
EyeH8the24
EyeH8the24's Avatar
ack was that a v6 astro ? are there diff gear ratios for the v6 and v8 ?sorry to hijack ,just thought it pertained
EyeH8the24 is offline   Reply With Quote
Old 12-20-2007, 04:53 PM   #5
68K20 x Drill
V6 have one less clutch plate, and a higher stall(behind a v8 anyway) convertor.
I think they all have the same gears.
And a few cars
Old 12-20-2007, 04:54 PM   #6
71Chevy4-speed
Speed Limit = Floorboard
71Chevy4-speed's Avatar
Corvette has a different servo and govener weights ( higher shift point's)
Really look for an 87 and up 700r4 with 30 input splines, these are the only ones worth even rebuilding.
1971 C20 350, 4-speed - Sold.
1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project.
"Build for torque, horsepower will follow"
71Chevy4-speed is offline   Reply With Quote
Old 12-20-2007, 04:56 PM   #7
71Chevy4-speed
They do have all the same gears, your right about the the v6's having a higher stall, actually its a cheap way of getting a slighty higher stall in your V8 is to use the converter for a S10.
Old 12-21-2007, 02:29 AM   #8
70GMCer
70GMCer's Avatar
I did not know that. What is the stall for a S10?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-21-2007, 05:03 AM   #9
Ackattack
Ackattack's Avatar
yeah, v6 astro.
I had a high performance rebuild on mine after I got it, so it got all the goodies, so I didn't really care what it came out of.
Old 12-21-2007, 10:02 AM   #10
lts70
1970 Daily Driver
lts70's Avatar
I have one out of a 1989 Chevy Caprice cop car. It ran good before I pulled it out. Is there any thing I need to pull off of the car to go with it before I junk the body? Should I just use it as is or should I put a different stall converter or any other parts in it first? Would the posi rear-end be worth keeping?
Thanks Guys
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 12-21-2007, 11:06 AM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
Doesn't really matter much. They're all so old/high mileage now they probably need a rebuild. The last 700R4's were used in 93. I used a rebuilt one for a Camaro for my truck. It's best to get one with better clutches and a corvette servo.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-21-2007, 11:39 AM   #12
68K20 x Drill
Thanks Guys
That is hard to say without knowing your intentions for the truck.
I can tell you the Cop Caprice is a heavy car that is tuned to 60-100 very well, and get decent mileage. Mine had a 3.08 rear. If your truck sees light duty use, and puts down 200-300HP , it should work pretty well as is.
The TV cable needs to be set up with just the same distance and angle on the throttle arm of the carb. I like the green coolant hoses cop cars came with, they are aviation grade. Welding new spring perches to a rearend is not all that difficult of a project, and would give you a 5 on5 bolt pattern. I would also keep the 120A alternator, or maybe the entire serpentine setup.
As I have read, the v6 TC stalls at about 2200 on an SS Impala, 200/300 over stock.
And a few cars
