12-20-2007, 06:55 PM | #1 |
frame difference?
Would a 67 frame and 69 frame be the same assuming they are both 1/2 ton 2wd c10's?
What I'm really wondering is if a 67 cab and front end will fit on my 69 frame. Last edited by jlaird; 12-20-2007 at 06:56 PM. |
12-20-2007, 07:03 PM | #2 |
fugedaboutit
Re: frame difference?
I know the front of the frames is different. The 67's and some early 68's had a wider section where the engine sits. Also no indent for power steering. Frame mounting should be the same though. Im sure others will chime
eric
Currently truckless |
12-20-2007, 07:12 PM | #3 |
its all about the +6 inches
for what you are asking, yes, you can install your early sheet metal on the later fram. The 69 and up is actually stronger acordiong to the dealers notes i have.
12-20-2007, 08:06 PM | #4 |
I JUST BOUGHT A REAL NICE 1972 C-10 BARE FRAME AND I WAS SURPRISED HOW FLIMSEY IT WAS WHEN I loaded it on my car trailer. almost made me want to install the 3/4 ton or 1 ton frame instead. i bet when i cut my c-notch i,ll really have to be careful about distorsion and install some braceing back in to restore its strength.
bob
I BELIEVE IN JOHN 3:16 |
12-21-2007, 12:53 AM | #5 |
3/4 ton frame is almost the exact same... just a few added braces here and there.
12-21-2007, 01:28 AM | #6 |
the rad support mounts are different between a 67 and a 69 frame as well. No big deal, you'll just need to use the later style rubbers.
Pete |
12-21-2007, 03:55 AM | #7 |
Thanks fellas!
12-21-2007, 06:21 PM | #8 |
i,ve got a 3/4 ton frame and when i redo my work truck i,ll install them if possible.
thanks andy bob
12-22-2007, 04:01 AM | #9 |
Born Psycho
Bob,
frames are made to flex, otherwise they would crack after years of twisting and off camber bumps and dips.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-22-2007, 05:16 AM | #10 |
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
