Lean/rich indicators ?
Are any of you guys running a lean/rich indicator sensor ?
MSD sells a kit, anybody used that one? Anybody got a set-up they suggest
Working on my first 1,000 post. I'm sure I'll get there before this project is over ![]() Last edited by Blue71LWB; 12-21-2007 at 12:59 PM. |
Old Skool Club
![]() Join Date: Jun 2001
Re: Lean/rich indicators ?
Short of having a meter (which I do) to measure the air/fuel ratio at the tailpipe, I have had more luck with my nose. If the mixture is rich, it'll bring tears to your eyes and burn your nose. On the lean side, it may be hard to crank when it's hot, because a lean engine runs hotter and the heat soak will affect the starter.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
That's right, it's Copper!!
I have the NGK AFX meter, it works great. I have used others but the wideband sensor is much better.
http://www.ngk.com/afx/ |
![]() Join Date: Dec 2006
Looks like a good thing to have. I notice you can get them on ebay for a lot less.
http://cgi.ebay.com/ebaymotors/NGK-N...ayphotohosting
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
your spark plugs will tell you everything you need to know
Innovate makes by far the best display I've seen
http://www.innovatemotorsports.com/products.php this controller may be decent, and the price is great http://www.14point7.com/JAW/JAW.htm Spark plugs may tell you everything, but a wideband with datalogging can tell you everything in one pull without opening the hood.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() Last edited by 68K20 x Drill; 12-21-2007 at 03:04 PM. |
yes, i do
but that link is a good one. i book marked it for future reference.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
I bought a a/f meter at AutoZone and installed unheated O2 sensors in the header collectors. Total cost was less than $100 including welding two bungs into the collectors. While narrow band sensors are tuned specifically for 14.7 a/f ratio and aren't as informative as the wide band plus a data-logger, you can still do a lot with them if you'll "mentally average" what the gauge is telling you. I've adjusted my Holley 750DP's jetting so that it's averaging 14.7 a/f on the highway, then turning mostly green (richer than 14.7) when I'm really getting on it.
If you have the cash, the better solution though is the wide-band + data logger for sure.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
In my Sierra I have a vacuum gauge mounted on the dash.It helps me gauge my fuel economy by letting me "gauge" my fuel to air mix.It`s amazing how a slight lift of the right foot can maintain the same speed,yet increase the economy.The gauge is color-coded to indicate Power,Driving,Idle,and Economy.In that order.I can roll along and consume less than idle.They used to put vacuum gauges in cars back in the early 60s.I don`t know why the government hasn`t mandated them if they are truly concerned with conserving fuel.
