12-21-2007, 01:51 PM | #1 |
bagging a 68???
how are you guys baggin your 68 c10's?? i want it to lay out, so tell me how you all are getting them to lay.
are you leaving the trailing arms in, and using the coil spring pocket?? are you using an upper and lower bag cup on the front? and where are you getting 6 lug 20's at? or is it cheaper to do a five lug swap and get 5 lug rims?? |
12-21-2007, 09:06 PM | #2 |
3DrDwn--the 'burb not the band
Re: bagging a 68???
If you want it to really lay (frame ) you'll need to either Z the frame or mod/replace the front x member. Also your tranny and link bar x members will need to be raised or modded. You will have a tough time with the stock link bars as they contact the frame before the frame contacts the ground. Use the search to find many previous posts that go into more detail.
six lug wheels are just, as if not more, common in 20"+ sizes due to the newer GM suvs are still six lug and all the homies rollin escalades in their music videos making that look popular.Cool thing is they have been high positive offset(fwd) since 88 and even stock wheels will tuck like a motorhome on our old trucks(some center bore mod. might be required for newer stock wheels). I don't think GM has a car app with the big 5 pattern anymore and even the compact and 2wd truck seem to be going to six. That said most companies still make the 5 on 5" pattern for their wheels. josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 Last edited by RunninLo; 12-21-2007 at 09:09 PM. |
12-22-2007, 04:31 AM | #3 |
Re: bagging a 68???
well im going to Z the frame, but is it better to mod or raise the tranny crossmember? and on the front do the bags have upper and lower cups
12-22-2007, 05:55 AM | #4 |
Re: bagging a 68???
when you Z the frame you have to move the tranny youthe same. for a front crossmember section you dont, most roun into streering linkage problems over 1.5" section.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
12-22-2007, 07:22 AM | #5 |
Re: bagging a 68???
Tucks like a Motorhome !! I Love it !
May I use that/ Thanks. |
12-22-2007, 09:30 AM | #6 | |
Re: bagging a 68???
I have the skills ( welding eng. degree with 15 years on the torch+ 15years air ride exp.) to do it my self but since I'm a lil older and now have a few more dollars than minutes I chose a bolt-in x-member swap. If you're going to pay a shop to do your Z it will more than likely out cost in labor what a good do it yourself bolt in x-member will cost. One brand name in particular stands out and a quick search of the board I'm sure you can find it. just something I picked up along the way. I heard it somewhere and can't take credit for it so please use it. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
12-22-2007, 01:57 PM | #7 |
Re: bagging a 68???
For the front, most guys use upper plates from ***************** and lower cups. Get the cups from airride, not suicidedoors. The cups from airride are a little smaller in diameter and will sit down in your spring pocket better.
12-22-2007, 04:00 PM | #8 |
Re: bagging a 68???
what size pipe does airide use??
