Addicted to Chevy
quick tach cluster question
Okay, my dad and i have been asking each other this question this evening -
Which tach clusters (what years) fit a '74? The difference, we believe is where the windshield wiper switch is located, correct? I am looking to buy some and need to know the exact ones to look at. also if there are part numbers, which ones to look for? P.S. this is my christmas present possibly, so dont tell mhicks ![]() Last edited by chev74; 12-21-2007 at 03:12 PM. |
Re: quick tach cluster question
Actually the two concerns are the presence of an ammeter or volt meter and mechanical or electrical oil pressure. You are looking for something 77 or earlier I think. Crossy would be the member to ask for detailed information on tachs.
Happy to be here
![]() Join Date: Mar 2000
Lets see if I can remember until Capt Kaos, Crossy or Russell come along to verify.
73-76= Amp or Ammeter, mechanical oil pressure 77= Volt or Voltage gauge, mechanical oil pressure 78+= electric oil pressure
The speedo shop tells me an HEI will fry the tach from a non HEI truck.
I just paid $260 to get one repaired.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
One shot, one kill.
Drill: I would think the speedo shop is incorrect. A tach is a tach. You can take a Sun tach and switch it into anything you want, even a magnito ign and it keeps on ticking, so I would surmise you could also do it with a factory tach. There is a seperate connection on HEI just for a tach. Yours MAY have a white wire in it now thats the one you want to connect to. The top of the connector block at the distributor actually says "tach". Let me know how you do. jim
Building a '74 truck for a friend awhile back he had a tach that didn't work. I checked all the wiring, and it still didn't work. I swapped in a newer motor with HEI, and it still didn't work (it did get warm if plugged in). Well, we though it would be cool to have the factory gauge, So we took it to Palo Alto Speedometer. It took them an hour or so to put a new board in the back, and it works great now.
They said sometimes the old points ones die if you hook up the HEI. I am somewhat skeptical myself, but with the repair running $250-300, I'll be cautious .
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() Last edited by 68K20 x Drill; 12-21-2007 at 11:34 PM. |
You want a 73-75 cluster. The telltale indicator is that it will have an AMP gauge.
87 short crewcab
I have a tach cluster from a 73 or 74,I dont know if it works. I had bought it for my 87, cant use it because of the speedometer,needs to have a speed buffer for the trans.
I would like to sell it if anyones interested. send me a private message with contact info. 87swbcrewcab donnie |
