12-21-2007, 03:56 PM | #1 |
Steering column question
The gear at the bottom of the column where the shaft bolts on has a lot of slop. The bearing is still there but there is nothing to keep the bearing up in the column...any ideas??
12-21-2007, 04:00 PM | #2 |
Re: Steering column question
Is the cup and c clip still on there? May need to replace the bearings depending on the amount of slop.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
12-21-2007, 04:07 PM | #3 |
No there isn't a cup or "C" clip...can you buy these somewhere?? Or can you take them off of another column??
12-21-2007, 04:13 PM | #4 |
You should be able to use them off another column. I have no idea if they can be bought anywhere new. I don't think there are alot of parts made for older columns anymore.(other than switches and levers)
Frank
12-21-2007, 04:27 PM | #5 |
Retired Air Force Veteran
you should be able to buy the parts from one of the following:
ATHEY'S CLASSIC TRUCK PARTS http://www.s-c-t-p.com/index.html GMC PAULS http://www.gmcpauls.com/ CLASSIC HEARTBEAT http://www.classicheartbeat.com/
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
12-21-2007, 06:25 PM | #6 |
along the same lines.... my shift lever is pretty loose (kind of flops around when going over bumps etc). Looks like the pin has worn out. I didn't see that part. Anyone know where to get this?
