Old 12-21-2007, 05:11 PM   #1
GREASEMONKEY72
GREASEMONKEY72's Avatar
Question popping sound at idle
my truck has a popping sound at idle and somebody told me once it was because of the 5 and 7 plugs wires touching, well ive made sure the wires arent touching and zip tied them up so they wont but ive still got that popping sound
i havent pulled the plugs yet but i plan to try and do that tomorrow to check and clean them and see what happens
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 12-21-2007, 05:22 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: popping sound at idle
Mine started doing that last week. I removed the plugs and found one of them that was bad. I went ahead and replaced them all.
To be honest, I've never had success cleaning them. I've always just replaced them. For about $10 or so, you might be better off having a set with you just in case.
68gmsee is offline   Reply With Quote
Old 12-21-2007, 05:37 PM   #3
GREASEMONKEY72
well i know the last time i cleaned them i didnt clean #7 cuz i felt i couldnt get it out without breaking it so i just left it but im going to do them all and not skip any and see what happens
-steven
Alte Seele S.S.
Old 12-22-2007, 01:23 AM   #4
wibilly
wibilly's Avatar
fresh engine , tired engine? pop through the carb or exaust? you could have burntvalves or not enough lash. have you done a compression test? also check your ignition timing
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-22-2007, 04:12 PM   #5
GREASEMONKEY72
im sure its tired but it runs good and its through the exhaust, i didnt get a chance to work on it today but im determined to wrench on it tomorrow
-steven
Alte Seele S.S.
