Old 12-21-2007, 06:53 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Door pillar issue. :(
Ok, so i tacked in my floor a bit and i ran into a problem, and im fuggin STUMPED. Here are some pics, the first pic is how it fits on the back side. The rocker. ITs flush and tight. Now, over the front side, theres this huge gap. What the heck do i do there??? I doubt the cab pillar moved forward. I measured door gaps and they are the same.... Is it that the rocker panel just doesnt fit well??
HEres the pics. See, it fits flush in the rear like its supposed to.
Here its not at all. Theres that gap at the top of the rocker. When i put the cab support on below it, its sill .5 inch away... any suggestions? Need more pics??
lyrikz is offline   Reply With Quote
Old 12-21-2007, 07:26 PM   #2
Rollie396
someday it will be done!
Rollie396's Avatar
Re: Door pillar issue. :(
I've heard stories of repop rockers fitting poorly and needing two to make one well fitting rocker.I really doubt the cab moved on you,they are very stable.Have you tried bolting up the door just to check for sure?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 12-22-2007, 12:08 AM   #3
DURRTY
USMC
DURRTY's Avatar
Are your body mounts shot? and is the radiator and fender on? all can move the pillar around.
that is a nasty rocker otherwise..
Semper Fi
DURRTY is offline   Reply With Quote
Old 12-22-2007, 01:41 AM   #4
Rokcrln
Rokcrln's Avatar
Looks like the standard rocker replacement these days! If the red line areas aor lined up then you need to slice along the yellow lined area to make it fit or buy a second rocker and section it. I think you will be fine with the slice method but you might want to hang the door to double check the fit bafor melting it all into place.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-22-2007, 01:41 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
that's not a slip-over rocker is it?
68C15 is offline   Reply With Quote
Old 12-22-2007, 03:25 AM   #6
mbgmike
WOw, we never had one that bad.
mbgmike is offline   Reply With Quote
Old 12-22-2007, 03:45 AM   #7
sleepyboy
'69 Step
Mine was that far off as well. I center sectioned it and added metal in the middle. I felt that the least intrusive because I have a billet cover for the top section and the standard stainless rubber trim holder. I'd verify it all with a door hanging also.
It's my truck, and Yes, I CUT the dash, so what??
sleepyboy is offline   Reply With Quote
Old 12-22-2007, 05:34 AM   #8
lyrikz
PITbut
lyrikz's Avatar
Kevin
LFD Inc.
Once i get the cab support on, tacked, then get the rocker tacked im hanging the door and fender, then going back and melting it on....
It just looks WWAAAY short... ahah very odd...
Old 12-22-2007, 12:09 PM   #9
GMC3
mine was like in the post above with the red and yellow lines. I had to slice where the yellow lines were, and then fill in with weld. Good luck!
GMC3 is offline   Reply With Quote
