12-21-2007, 07:06 PM | #1 |
What Camshaft are you running ?
I want to know what camshaft you guys are running or recommend ? It will be in a basically stock 350 with only a performer intake . I want something I can hear but what is too big . CompCams 270 ? Anyone running one of the Extreme Energy cams in that range ? Frank
Born and proudly residing in a Red State ! |
12-21-2007, 08:57 PM | #2 |
Garage Queen Material
Re: What Camshaft are you running ?
i'm running a comp cams 270H Magnum
though i wouldnt recommend it for a mostly stock build. it isnt to wild, but more than a stock engine should use. |
12-22-2007, 02:50 AM | #3 |
I have a Summit copy of the Edelbrock performer cam. It has a slight lope. My 350 is basically stock with headers and double hump heads.
12-22-2007, 04:15 AM | #4 |
I got the comp cams 270h.. but I got dart heads etc.. I have put this same came in stock motors and it performs well.. Its a good all around cam. I think its the biggest you can use with the stock converter.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
12-22-2007, 05:51 AM | #5 |
Comp 224/228 .588 lift on a 112 LSA
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
12-22-2007, 06:04 AM | #6 |
Active Member
Location: West TN (Memphis area) now. East TN (my favorite place to live).
I am running a XE-294. I love the cam. Too big for daily use. One thing with the XE cams, they make a lot of noise. Sounds like lifters are tapping.
BigFredTN 70 chevy stepside 350 with some goodies inside, turbo 400. 69 Chevy long wheel base. Dad bought new in 1970 62 Chevy Impala 98 GMC Yukon 1970 Ford Mustang Fastback I know its a Ford. |
12-22-2007, 09:20 AM | #7 |
Summit 1102 kit which is the same as the Edelbrock Performer, only much cheaper. Good cam for stock heads, stock valve springs and 8.5:1 compression. Has a slight lope at idle which is nice and it's very streetable.
12-22-2007, 10:38 AM | #8 |
On a budget like Fred Sanford
Buddy of mine runs that cam in a stockish (intake/headers/duals) 350 in his '85 3/4 ton 4x4 with 35" tires, sm465 and 3.42 gears. It's got a little rumble at idle and has tons of torque. Good cam.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
12-22-2007, 02:39 PM | #9 |
I have a comp cams 280h in a 350 10:1 compression and severly ported 461 heads.
It has a fair lowend and a awesome top end,and a great rumble at idle. but i wolud not put this cam in a stock engine |
12-22-2007, 02:44 PM | #10 |
The CC 260H is a great daily driver choice. That 1102 (which I'm betting IS a rebranded Edelbrock Performer cam) is a great truck cam - I'm planning a build with one right now after getting turned on to it in the DD thread
12-22-2007, 02:55 PM | #11 |
i have a blue racer cam 280 duration 488/510 lift in my 1974 daily driver with camel hump 461 heads(2.02/1.60) and 550 lift springs. it dynoed 310hp to the wheels with 298 ft/lb of torque
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
12-23-2007, 03:10 PM | #12 |
Thanks for the responses . The 1102 cam or the 270 sound like the way to go . I am going to research the performer style cam . I do want to hear it at idle . I have given thought to a pair of Dart iron heads etc. but I dont know if it is worth it since the truck is just a driver . Frank
12-23-2007, 04:26 PM | #13 |
Right turn Clyde
For the summit cam and lifter kit its SUM-K1102 its 89.95
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
12-23-2007, 05:02 PM | #14 |
The Summit kit is a really good value. It's a white box but don't let that fool you, it's from a major cam grinder. I want to say Melling, but I've never confirmed it. When I ordered the kit, they sent Sealed Power brand lifters. I went to Edelbrock's website and downloaded the manual for the Performer cam with the same specs, which gave me the recommended initial and total timing for the cam.
12-25-2007, 06:18 PM | #15 |
I have a Comp 280H with 1.6 rockers in a plain-jane dished-piston, 487X headed 383... It has a very distinct idle and has good performance, and with the low compression will run all day on 87 octane...
12-27-2007, 06:45 PM | #16 |
I've got a Comp (#12-422-8) Retro-roller in my 9.0:1 350sbc, with SR torquer heads. Havent had a chance to drive my truck as of yet due to the fact that its still a resto projet, but it has a very sweet rumble, to a slight lope to it which is based on the EX268. Hope this helps
12-28-2007, 09:50 PM | #17 |
krazy hillbilly from Kentucky
obviously running a roller. Retro-fit or 88+ engine?
1969 Chevy CST/10 "Old School lives and breathes in the heart of a chosen few " 1984 Chevy C10 Silverado "Life, Liberty, and Ford's Pursuit of Chevy taillights" You say "Obsessed with my trucks" like it's a bad thing |
12-28-2007, 10:03 PM | #18 |
Appears as though I'm running the biggest single pattern cam. I'm running a Comp Magnum 292H. 244*/244*, .501"/.501" lift, 110 LSA, 106 ICL. It's a very big cam and very tricky to set and very touchy to maintain. It's not something for a stock engine, nor is it good for daily driving, mainly cuz vacuum is non existent. My brother is running the 270H Comp, distinct idle, works with stock converter and heads. Bout as big of a single pattern you want to go with. Lunati has the Voodoo Series out now that is an amazing dual profile cam, they are slightly more expensive, but they outperform others. With that one, I'd go with a 262 cam. I'm running a full profile circle track SB in mine. .120 domes, 400 heads, 2.02/1.60 stainless manleys put in. Full porting work, deshrouded valves, milled to a final compression of 10.85:1, lightened crank and rods, 292 cam, mech. lifters, single plane high rise intake, reworked 830cfm spreadbore holley. Scorpion alum bodied roller rockers, 1.47" springs, 10* locks, BBC oil pump. I'm a big of an engine builder.
12-28-2007, 10:08 PM | #19 | |
