12-22-2007, 09:52 AM | #1 |
factory a/c freon ?
I have factory a/c on my 72' and I was wondering what is the best freon to use? 1) a conversion kit from 134 to a R-12 system, 2) R-12, or 3) a freon called freeze 12? Thank you.
12-22-2007, 01:14 PM | #2 |
Old Skool Club
Re: factory a/c freon ?
I used Freeze-12 in a '91 Celica, and it worked great. If your system is intact and just needs freon, give it a try. R-12 is not cheap, and the Freeze-12 is available without any hitches. If you have to convert to R-134a, there's a few things that have to be done to make it all compatible. I saw an ad in one of the truck rags about a company that says they have a conversion compressor for our trucks that will run R-134a. It isn't a reconfigured compressor like ours uses, but a new compressor designed to work with our mounts.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 12-22-2007 at 01:14 PM. |
12-22-2007, 03:09 PM | #3 |
Where can I get freeze 12?
12-22-2007, 03:43 PM | #4 |
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
